Thank you very much, getting it!
Although how can I connect PS3 to my 2.1 speakers? :s
http://www.newegg.com/Product/Product.aspx?Item=N82E16836119008 < these?
10e said:Can't you use the PS3's standard AV cable which comes with the unit, find a female RCA to headphone jack converter and get that to go line in to the sound card directly? This requires being set to the A/V SCART audio setting.
When the monitor outputs sound to the headphone jack it is slightly amplified (for headphone usage) which may be above the tolerance for the line in. Line in is not supposed to get amplification.
Basically you need a cable with two female RCA to one 3.5mm headphone jack.
Something like this:
http://www.monoprice.com/products/pr...t=1#largeimage
Attach the PS3s red and white cables out, and then straight to the sound card. Forget about the HDMI audio through the monitor it doesn't work properly going out through a headphone jack as it is.
Received my BenQ G2400WD today and noticed a dark gradient across the screen.
The top of the screen is darker than the bottom but I don't think it's enough to make a fuss over. Does it get any better with use/time?
Also, how do I enable the 1:1 mode (Where it's letterboxed I think) over my Xbox 360? I looked through the BenQ manual and couldn't find it. It's probably something obvious but I can't figure out how to do the 1:1. Thanks!
Dark gradient across the screen? If you view it from a slightly higher level does it improve a bit?
Yes, it's in "Picture - Advanced" > "Display Mode" I believe. You should have three options > Full > Aspect > 1:1.
Aspect or 1:1 should work great with Xbox 360 over HDMI.
Yeah, the dark bit is more at the top of the screen. I've read about it on a few reviews as well....
I can't select the Display Mode item for some reason, it's grayed out.
You can improve it a bit by aligning the middle of the screen with your eye level.
And the display mode stops being grayed out when you're receiving a non-native signal.
Has anyone used this LCD on a PowerMac? Overall impressions?
I intend to use it mainly for graphic work and some video editing. Comments appreciated, thanks!
Alright thanks.
What do you mean a non-native signal? The Xbox 360 only goes to 1920x1080 which isn't the monitors native resolution (1920x1200 right?) I am connecting through VGA if that matters. Help?
Has anyone been able to measure the input lag? Also, how's the responsiveness compared to say LG's L227WT?
I dunnoit worked for me when I had my x360. Try a different console or something and see if its still grayed out.
http://www.digitalversus.com/duels.php?ty=6&ma1=48&mo1=304&p1=2943&ma2=35&mo2=349&p2=3278&ph=12
Well, got an RMA number lined up with Buy.com. I'm including some pictures and a CD with video of the tearing to help my return. It'll go in the mail in the next few days.
Has anyone noticed that when using HDMI, you can't switch inputs while the XBOX is on and go back while it's running without having it reset on you? This is a HUGE nuisance to me! When using DVI, it doesn't do this. Is there ANY way to avoid this? I'm thinking of getting an adapter so the 360 thinks its using DVI, but adapt it to HDMI so I can use DVI with my PC and HDMI with the box. VGA on this looks really really bad.
Hopefully my replacement remedies all my issues!![]()
Oh, sorry, I forgot to mention that I'm talking about G2400WD. I can't rely on the graph for the old G2400W because overdrive/RTC does in general induce some input lag.
Everybody says G2400WD has the same panel as V2400W, which has some input lag.
Overdrive/RTC can be toggled off and on with the G2400WD/V2400W.
I can confirm that DigitalVersus.com has correct numbers for the V2400W, so I"m assuming the G2400WD will be the same as it's the same panel inside. I can't comment on responsiveness vs. the L227WTG-PF though, but it should be fairly competitive.
Turning off overdrive/RTC defeats the purpose of this monitor as a gaming monitor, meaning this will force you to either have a high response time or high input lag, which in either case isn't good for gaming
I could buy this monitor today, but I don't want to knowing that it might have input lag.
I just read your review, where you say V2400W has no input lag compared to G2400W, and at the same time DigitalVersus has the correct numbers, but on DigitalVersus the G2400W has no input lag, while V2400W has input lag. Could you please clarify?I can confirm that DigitalVersus.com has correct numbers for the V2400W, so I"m assuming the G2400WD will be the same as it's the same panel inside.
Should AMA be left on or off?
Are the inverse ghosting artifacts that visible? Like with the Samsung 226B with non-Samsung panels?
how's this compared to the V2400?
guys I need a really quick reply. I've got a chance to get a Dell E248 for about $80 less than the BenQ G2400W. Which monitor would you guys choose between these two? Is the BenQ better than the Dell? Does the Dell do 1:1 pixel mapping and have all the other features of the BenQ?
Can you guys use 1:1 mode at 1680x1050 resolution? My G2400WD won't do it. Every time I try it goes back to FULL mode.
No, the V2400W won't do it any more either. The G2400W did it just fine in 1:1 ratio.
Stupid firmware. Two steps forward, three steps back.
Is it noticeable at normal viewing distances? Is it noticeable without taking photos of it?For some reason mostly on dark objects on light backgrounds like text... In games I couldn't detect it with PC, PS3, or 360 games.
Does anyone know if this monitor can do 75hz without skipping frames? (G2400WD)
anyone?
