Can't you use the PS3's standard AV cable which comes with the unit, find a female RCA to headphone jack converter and get that to go line in to the sound card directly? This requires being set to the A/V SCART audio setting.
When the monitor outputs sound to the headphone jack it is slightly amplified (for headphone usage) which may be above the tolerance for the line in. Line in is not supposed to get amplification.
Basically you need a cable with two female RCA to one 3.5mm headphone jack.
Something like this:
http://www.monoprice.com/products/p...id=1021804&p_id=666&seq=1&format=1#largeimage
Attach the PS3s red and white cables out, and then straight to the sound card. Forget about the HDMI audio through the monitor it doesn't work properly going out through a headphone jack as it is.
Sound good? oops, pardon the pun
10e
10e
Has anyone came across problems trying to send the monitor's audio output from the headphone jack to the computer's input jack without the sound being buggered?
When I first ran the audio from the monitor to the soundcard, it sounded distorted, even if I played around with the monitor's volume. And now, I can't even get the sound out anymore. I have to either move the speaker's jack from the sound card to the monitor directly and visa verse. Or set PS3 to output audio through "Audio Input Connector / SCART / AV MULTI", then connect those cables to the tv box, then output the audio from the tv box to the sound card. It sounds better than when connecting from monitor to sound card, but then it has a buzzing noise. Plus, I feel that the sound lags behind a little, I feel. I dont know if the lag is all in my mind because im expecting it to be there if I connected: PS3 -> TV box -> PC -> Speakers, while the display is just: PS3 -> Monitor.
So my question is, how do I set up my system in such a way that I get the following results:
PS3 -> HDMI (including audio) -> Monitor -> Soundcard -> Speakers,
whithout the sound being buggered?
Any hints on how I should configure the sound card?
What should I set the Monitor's volume level to be so that it doesn't mess up the sound?
Which audio output formats should I select in the PS3's audio settings, Im not sure which ones are supported by the monitor and which ones are not. Im speaking here about the frequency and not channels i.e 44.1 kHz, 48 kHz, 96 kHz, 192 kHz.
But for interest's sake, how well does the monitor handle down mixing from 5.1/7.1 to 2.0.
Should I only send 2 channels to the monitor?
If this info will help, im using the Sound Blaster X-Fi XtremeMusic 7.1.
All I really want is to use the soundcard together with my S750s gigaworks speakers as an all round sound system. Every thing must go through the sound card.
Any suggestions will help.
BTW, please dont suggest that I spend more cash to solve this problem. You can imagine what the soundcard + speakers + monitor + PS3 add up to.
