Ok, I'm going to pull the trigger on a BenQ monitor after reading good feedback here, thanks guys.
But I am very confused about which monitor to get. With the promo code, the V2400W is about the same price as the G2400W and G2400WD. I am looking for the best monitor for fast fps gaming on the PC over DVI and the XBOX 360 over HDMI. I know it is a TN, but I am hoping the vertical viewing angle isn't horrible like the Gateway FHD2400 I had to return. That is why I am leary of buying online where it is a pain to return it. I also need the model with the speaker output to hook up to a stereo system for the XBOX HDMI use. From what I see at face to face, the older G2400W is actually faster/less lag than the new V2400W?
http://www.digitalversus.com/duels.php?ty=6&ma1=48&mo1=365&p1=3386&ma2=48&mo2=304&p2=2943&ph=12
I don't care about the slight difference in prices of these 3 models, or the external looks. I just want to get the best one for me (best viewing angle vertically, best picture, and lowest lag, fastest response time and all the input/outputs I need). Can someone who has used two or three of these models let me know which to buy? And a stuck pixel would definately drive me crazy, so I assume I should buy directly from Benq in case I need to return it. Thanx
I got my G2400WD from buy.com today. It only has one bad pixel but it doesn't bother me at all.
I am having a problem with the screen randomly flickering. Has anyone else had this problem?
I am just doing some general web browsing. The flicker is on and off. It will just starting doing it all of a sudden and then stop for a few minutes. I just got a new Nvidia 8200 IGP motherboard. Could it be the video chipset?
Only thing that bugs me is the DVI input doesn't display until vista is loaded. Anyone have an idea on that?![]()
I'm thinking about buying this monitor and I think I read this same thing on one of the Newegg user reviews.
So let me get this straight the image appears black/blank? until Vista loads up? If that is the case how do you go into the BIOS if you're overclocking to adjust settings? Why does this happen?
If anyone could answer this question that would be great. Thanks.
This happens to me with a completely different monitor (Westinghouse LVM 42W2) and I've tried asking about it a few time at various places but I couldn't get any definite response. One of the most common suggestions was that the problem lies with my video card - an old Geforce4 Ti4400...
I know this comment doesn't really add much to the convo but I am looking for a new monitor, and would love to know why this happens.
Also, when I need to get into the bios i haul out my old 17" crt...
I have your same concerns.I have heard that older ATI cards had this problem with the Samsung 2493HM also. First off, if you are using that old of a video card, forget a monitor at 1900x1200, your games will crawl at 1fps. However, I would like to know if the V2400W or the G2400WD have any problems displaying the bios with a newer (Nvidia 8,9 series) video card if anyone knows, please chime in. I guess worst case scenario, when you need to get into the bios just use it VGA. It comes with a VGA cable and I assume you have a DVI cable, with a new graphics card you can have both hooked up to these monitors at the same time and chose whichever works (though you may have to unplug the other). Can anyone verify that they can see the bootup/bios screens with these monitors over DVI?
...snip...
I've got a new system on the way: New Buld.
Not much pc gaming at 1920x1080, other than the odd UT (original) match. Xbox360 is a diff story.
I'm anxious to find out if the no bios issue will prevail once I get my new PC, then i'll know for sure if it's my video card or the display itself.
I am VERY anxious to find out about the BIOS display issue too. I will probably be getting one of the new ATI 4850's or 4870's to run it off of or maybe one of the new Nvidia variants depending on price. So this sounds more of a video card issue rather than a Monitor issue not displaying an image until Vista loads up?
So would it be safe to assume for most people it displays an image before the OS boots up and just a few are experiencing this no image/blank screen problem?
Also, does it happen in VGA too? Is there a difference in video quality with DVI Vs VGA?
Any update or other LCD you might suggest?Hi (10e)
or anyone who got this LCD
I was able to get it for 300$ , after your review
I had FP241W (Grrrrrrrrreat LCD)
When compared to the G2400, the G2400 looks dull (Clone Mood)
I did not understand how did you find that G2400 colors where better than FP241W))
and this is my first TN LCD , I had it for 6 Days and still could not calibrate or find the best angle (the darker upper side irritates me 2 mush)
Please may you send me your calibrated profile or what settings you use, and how to minimize the upper dark effect
I could get the 245t (SAMI) 4 have the price, do you advise me or I should stick to g2400. Or what options do I have ( I can still return It) Will be using it for Videos some gaming and office work
Thanks
I have tried the monitor with mostly newer cards:
8800GTS 640MB G80, 8800GTS 512MB G92, HD 3850, 3870, 3870x2. Never had a problem with BIOS screens. If there is an issue, I would recommend finding new BIOSes for those cards to fix the issue.
I have heard these complaints with other monitors like the Gateway FHD2400 and the Samsung as well, but I don't know the source, or understand the problem, but it may be centred around older video cards like 9700/9800 ATI cards and 6x00 series nVidia.
Regards,
10e
Cool so I should be OK then if I use a newer card? I just read a few times over the the last week or so about the screen being blank until Vista loads up, which really put me off getting this Monitor. I want to overclock so it would be useless to me if I can't view the BIOS screen.
btw any chance you could take a look at the thread that I started http://www.hardforum.com/showthread.php?p=1032660474&posted=1#post1032660474 and tell me which Monitor you would choose out of the ones I listed?
Just wondering why is everyone still buying g2400w and not the g2400wd? Isn't the wd an updated version of the w. And does the wd correct some of the probs the w has? specifically the black bar flickering deal on the hdmi?
or is it the same thing except the added dynamic contrast feature?
Thanks to those who've posted. Esp 10e. Just bought 2 of these.
Unfortunately one has a strange problem.
When the monitor goes into sleep mode, the message "No Signal Received" flashes and then it goes into standby mode, but a couple of secs later it keeps flashing "No Signal Received" over and over and over again like it keeps going into sleep mode. Sometimes it does this even after I shutdown my computer.
By the way it has no problem waking up from sleep mode.
Has anyone got any ideas as to what could be causing this?
It's only a problem on DVI. Doesn't happen on VGA or HDMI. I've swapped DVI cables with the other G2400W I got and I've tried it on another system and it still does it.
I notice that the supplied DVI cable is single link. Would getting a dual link make any difference?
Pretty sure it's not how it's supposed to be because my other G2400W just comes up "no signal detected" once then goes into power saving mode.
This one can still be flashing "no signal detected" hours later after my system has gone into standby.
I'm going to take the 2 hour drive to return it this Sat![]()
Hopefully the replacement has no dead or stuck pixels as this monitor is perfect apart from this one problem. Risky!?![]()
