·PitBuLL·;1040267176 said:The server lag for me has been absolutely brutal as of late...
It's a PDW, not an AR. And it's just you. Stop going full auto and recognize that the gun has limited effective range. Fire in bursts if you must use automatic mode, and try to pick guys off rather than engage groups.
Eventually, you'll unlock the AK5C after getting enough points with the MX4. The AK5C might be the best gun in the beta.
I can't believe you get two heat seekers in the heli then you have to wait like 30+ seconds to get just one more. Who thought of that?
If your CPU usage is like 80% or more overall and GPU usage is low, that's a bug, not the intended performance. It causes stuttering and such. I have that problem and have not been able to fix it. It's hurting my ability to judge this beta.
Yeah, for some reason afterburner overlay isn't working (for any game on my part), but I've ran it in windowed to monitor both usages. GPU sets at 40-50% while all CPU cores are 80 - 95%
What advantages does it have over the rifles?
Afterburner lives in the past and has no 64 bit support.
Johan Andersson
Spent last 24 hours fighting PC graphics driver thread contention & stalls in #BF4. Believe I've won this battle, but not yet the war
Luke Rothwell
Can you please address the cpu usage problem before the release of bf4 Thanks
Johan Andersson
that is exactly what I just said I've been working on![]()
Johan Andersson
So expect some improvements in the next #BF4 OpenBeta patch. Though Win8 w/ our DX11.1 backend is definitely the fastest path (until Mantle)
Vassily
But we don't wanna buy W8 just for one game...
Johan Andersson
and neither do you have to. Windows 7 should work fine, please test after the OpenBeta has been updated
Would it be sad to upgrade to Windows 8 just for this game?
sorry if posted guys.
but a patch is coming for the beta.
not sure why i cant post the link.
Did anyone notice the 25% XP booster? One booster gives 25% XP for one hour. I don't think you can deactivate it after starting the booster, though.
Last night I installed the 8.1 preview coming from 7. I can without a doubt say that it does indeed boost the performance of the Battlefield 4 beta. On my Sony fw900 I tried 2560x1600 and with everything maxed out I was getting a constant 45 to 50 fps and a few hiccups that dipped into the 30s. At 1920x1200 I was getting fps in the 70s. Dipping to the 50s in heavy scenarios. I'm using the current 331 beta drivers. I'm just amazed at the level of performance that was noticeable. Im sure they'll Do a fix for those on windws 7 but with BF4 using frostbite 3 and dx11.1 is standard in 8. I'm upgrading to 8.1. GPU is overclocked to 1250 but boosts up to 1289 and memory is 8000mhz. Hope this helps anyone who had stuttering problems in the beta.
PS. My Windows 7 performance in the beta prior to installing the 8.1 the fps was all over the place. It was unplayable.
Same here. I can say I've had a much better experience on 8 than on 7. 8 has some major under the hood improvements over 7, and 8.1 apparently has further improvements.
I totally understand the resistance to Windows 8, but if your number one objective on your PC is to play games, then 8 is worth it.
I gotten two boosters in battlepacks thus far, but don't know how to activate them.
Is windows 8.1 as terrible as windows 8?
Is there a legit start menu and windows explorer now?
Considering many upcoming games will be using FB3 engine and it has been confirmed to run much better in windows 8, it may very well be a good idea to bite the bullet on W8.1.
when you are customizing your kit ingame the boost thing is at the bottom right of the screen
Just use Classic Shell if you want a start menu / tweaked explorer on W8. You never have to see Metro again if that's what you want.Is windows 8.1 as terrible as windows 8? When I checked it out when if first showed up I thought it was an abomination. Is there a legit start menu and windows explorer now? Considering many upcoming games will be using FB3 engine and it has been confirmed to run much better in windows 8, it may very well be a good idea to bite the bullet on W8.1.
Why does a little part of me feel like it is dying when I think about leaving W7 for W8? LOL.
I am planning on upgrading my system soon anyway. Seeing all of these posts with the dramatic improvement over win7 for this game is making me considering Win8 for the first time.
Decisions decision.
Heck, I'm probably just going to get a new SSD, Win 8, grab a 290x........ BF4 will be my 'reason'.
Wow, that performance delta is crazy.
