joebobsteve
- Apr 12, 2010
Weak. They swapped out 7.1 audio for Wifi and Bluetooth. Its better to use USB wifi/bluetooth than USB 5.1 audio.
Not sure if this is off topic, but will throw it in. ASRock is releasing a Sandy Bridge ITX board that uses full DIMMs. Looks like my build will hold off till the end of Jan. Between the new boards and GPU releases coming out then it should be awesome.
http://img121.imageshack.us/i/asrockh67mitxhto01.jpg/
God I love seeing multiple ITX boards show there faces before the platform is even released.
Ok, so far I have found that Gigabyte, Asus, ASRock and ECS are all making mini ITX boards. At least 2 of them are using full size DIMMs. Asus is using SO DIMMS and havent found a pic of the Gigabyte, only statements saying they are building one. Theres another thread for the Asus, so here's what I found on ASRock and ECS
http://www.hypergearmag.com/events/e...w - Tablet
http://www.tcmagazine.com/tcm/news/h...therboard-line
This is awesome, I just wish there was a better selection of mITX cases out there, they all seem more or less the same right now.
& that seems to be more or less an uneducated response.. weather it be tower, desktop or cube mITX has it covered.
The mITX form factor is just recently starting to become more main stream. If you think that case designs for it have been fleshed out as much as ATX or even mATX, then you are a fool and / or have no imagination. Calling my response uneducated just makes you look even more foolish, you have no idea of who I am, what I do, or what my opinions are based on. You might not agree with my position, but I assure you, it is quite an "educated" response.
For one, I would like a case that does away with space for optical drives, has space for two 2.5" drives, and stands all the components vertically (I hate how deep most of the current cases are, they really don't need to be more than 7" deep or so if you do a vertical config). Something like a mini FT02 (and not the mATX monstrosity that Silverstone showed off recently). You could also have a big 140mm fan at the bottom with a removable filter and some laptop like hinge on top to access the ports instead of something you have to snap off to change a cable.
Doesnt the Fractal R2 skip the OD? Of course its over 7" deep. Part of what keeps this fun is seeing the different viewpoints and ideas. Myself, I want to keep the OD. It can be slim and I have no problem with 2.5 drives. Heck, my current project will start with a leftover 2.5". Since I want to do some light/moderate gaming a 7" deep case isnt going to cut it. If I get some better graphics I may become a heavier gamerPersonally, I'd love a Q08 cut down to 270mm in length. (Smell possible future project
Anyhow, I would love to see more options for cases.
OK guys-hold on. I think I see part of the dispute. As far as being desktop/tower/cube there are indeed options for ITX. But I just did a quick peruse of Neweggs cases for Mid ATX and there are over 300 options. Something for every price range and taste (most of which I thought sucked-personal opinion) ITX cases, by comparison, have limited options. Fortunately, a higher percentage are much nicer cases.
So, yes ITX basic configurations are covered, but we dont have nearly as many options for individual taste.
Now that I agree with. I am currently waiting on a Q07 that I got over the Q11/Q08 due to the footprint. I really needed to keep it small. Good thing theres some good GPUs that will fit. If the Q07 didnt have OD that space could house a 120/140mm exhaust fan. That would mean 2.5 HDD on the floor and removal of OD cage. Just a thought. But, like I said, I am using the OD. Though, if I convert to slim OD a slim 120mm might fit, hmmm.(Last post I make off topic-sorry)
BTW, I decided against the CoolerMaster PSU since I discovered it was 160mm long. Going with SeaSonic 520W and will mod cables. Half of which I wont need at all.
the SeaSonic was $20 less. Adding the PP05 would make it $40 less. For $40 I will mod cables. Putting in perspective I saved 25% on PSU alone. Admittedly using the Silverstone and short cables would be easier. And wouldnt void a warranty. But for the difference I will risk it. Besides I got not much else to do while sitting on my behind reading forums all day. Not much work for me. Price is now higher on the SeaSonic than when I bought it. If I was buying now I would get the Silverstone. Still need board, CPU and memory. Will get those in Jan.
Just reread the Asus AMD itx review and the SB board needs to beat that for me to get it. Cant wait!
As for the remaining hardware besides the still needed mobo, cpu and ram, the only thing left is the GPU and more than likely it will be a gtx 460. I considered the Corsair but after reading the reviews I reconsidered. If I am going to void a warranty I should best not need to worry about using it! And since I keep stuff a LONG time (current setup is 4yr old laptop-and it wasnt anywhere near the top of the lineup) I overdid it on power. I did research and at the watts I need this thing is very efficient. Like 87%
And after reviewing currently listed SB mobo's I think I will be going with the Asus-WiFi and USB 3. none of the others listed having both.
It might be cheap componentwise but the manufacturing costs are probably higher due to lower volumes.
I Doubt that there will really be lower volumes.. Going forward more & more mITX boards will be making there way into OEM systems more so then the larger boards since the R&D will already be done as well as the manufacturing process. There is no reason to put a mATX or ATX in most OEM systems.
