wwischerath
- Oct 18, 2010
Cool with me
ECS will have a mini ITX board out by the end of June. Has everything that the Asus board has except for WiFi and it uses regular DIMMs. It does have a mini PCIe slot that accepts mSATA.
Right Now: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131727any idea when thats supposed to be available?
Unfortunately, it's probably not going to w/o modding -- it's probably going to be REALLY close, though, like maybe 1-2mm or so
The SG05 and SG06 have the same internal volume/dimensions (minus the front panel bumpout for the 06) and my 6950 barely fit into my SG06 after I cut out the interior metal plate and shaved down the plastic bits on the inside of the front panel.
Of course, you might have a non-reference 6970 and I might be eating my foot shortly
Does anyone know definitively if either of the fan headers can be controlled via QFan in the Bios via voltage control (so I can use 3-pin fans)? Both headers are 4-pin (PWM). The selection of 3-pin fans in 10x that of PWM fans, espeically when you're trying to build a quiet system, so hoping to be able to use 3-pin fans & also use the ASUS fan control to keep things simple.
The manual only has the following blurb on QFan, which isn't 100% clear on the topic:
"Only the 4-pin CPU fan and chassis fan support the ASUS FanXpert feature".
there should be fan controll on the second header (also 4pin), but I think it's PWM only, it's running my GTAP13 at max speed.... no matter what I setIf it helps, I've got their M4A88T-I AM3 board and I'm able to use QFan on both the chassis and 4pin fan.
for the guys that already have this board, does it have any undervolting options?
Ya this thread, and the information in it, seems to have morphed into an H67 thread.?? Asus P8P67-I? does it even exist? all I can find is H67
