Excited to read HardOCP's review of the chips. Until then ill be putting money away to build a new system.
It's all vapor until the chip is running on the bench in front of you.
/End thread
It means they finally caught up to Sandy bridge IF and ONLY IF they can make it clock near 4Ghz.
All rumors about GloFo's process this will be manufactured on - however - suggest that it will be tough to get clocks much above 3Ghz on them.
I was hoping to see some hint about potential clock speeds in this slide deck to dispell those fears, but I saw nothing, and the continued harping on IPC without mentioning total performance or clock speeds makes me suggest that it is true.
In other words, IPC will me massively up from Piledriver FX chips, but clocks will be massively down, resulting in an overall 10% performance increase, when they really need a 60% overall performance increase.
Expect to see AMD trying to throw more cores at the problem again, just like they did with bulldozer, when we all know that with the exception of some narrow usage cases, what really matters is single threaded performance.
I had high hopes for Zen, but it's starting to look like its going to be another Bulldozer sized disappointment.
I donno if it has 8/10 cores or something.. 3.0 ghz might be about right.
Unless you were one of those that complained about this 3.0 Ghz also?
***** Intel Core i7-5960X Haswell-E 8-Core 3.0 GHz LGA 2 011-v3 140W BX80648I75960X Desktop Processor
*cough* GTX970 *cough*Some people hate scammers and con artists. Whether AMD's marketing department is one or the other of those is good question.
I am really hoping Zen outperforms expectations just to give AthlonXP a reason to change his name!! The guy has been suffering long enough!!
does this mean AMD finally caught up to Sandy Bridge?
Try Broadwell-E troll
I just hope that the CPU is competitive with Intel's latest, whatever you think of AMD or Intel, we all need competition to drive performance and value for money, so I personally hope that AMD have a winner here.
No, he's right.
I don't for a second believe that test is anything but a single benchmark anomaly.
If the 40% IPC over Kaveri statement holds up, AND they can hit 4ghz thr best they are going to do is tie the single threaded performance of a Sandy Bridge core i5-2500k which will be six years old when Zen launches in volume.
What's worse is that everything suggests that hitting much above 3ghz is going to be difficult on GloFo's process.
This means while we might see 40% IPC improvement, it will be accompanied by massive reductions in clock speed, and actual single threaded performance gains over Kaveri are more like 10%, which doesn't bring them anywhere near Sandy Bridge![]()
Just as performance cannot be derived from one benchmark nor does a processor perform similarly in all workloads. AMD's BD arch is already at or above 2500K if we are talking about encoding or well threaded streaming workloads.
I agree but that's not what we are talking about here. Going off the benchmark both processors were at the same clock and the same number of cores. If IPC was in the tank then the comparison wouldn't even come close. Even if you compiled a custom code path for the processor.Yeah, but that's like 0.5% of typical workloads. The most important CPU benchmark of all is single threaded performance, as it speaks to how good the architecture is.
Adding more cores to make up for poor single threaded performance is just a last ditch effort that results in lesser performance in the overwhelming majority of tasks.
Not arguing that. Just saying that making a blanket statement that AMD needs a 40% boost across the board isn't entirely accurate. They need a minimum of a 40% boost at the same clockspeed whenever single core performance is more desirable.It is not a matter of "if they only could improve threading in code". Not all code is thread able, no matter how hard you try. Pretty much with the launch of DX12and the state of things, code is about as threaded today as it will ever get. In all but a very few workloads, having fewer zippier cores is vastly superior to more, slower ones.
Why would you voluntarily buy a CPU that excels only at a tiny minority of tasks, I stead of one that performs well at everything?
true, but even if it gets within 10% of sandy bridge at least it's competition so i'd be happy. we'll have to wait and see though.
No, he's right.
If any of you think Zen will only reach SB IPC levels, then you've lost all your marbles.
And here I thought it was Haswell/Ivy Bridge they were shooting for which would only put them 2-3 generations behind Intel, depending on if you are comparing to Broadwell or Skylake.Other way around. If you think it will beat SB in IPC you have lost your marbles. Kaveri is more than 40% behind SB in IPC. So, adding 40% IPC doesn't bring you to SB levels. It's that simple...
Sandy Bridge has approximately 54% higher IPC than Kaveri.
So, if you add 40% to Kaveri (like AMD claims) you are still 10% or so behind SB.
And AMD's claims tend to be exaggerated anyway, so the real IPC gain is probably less than 40%...
The blender render test AMD picked was obviously picked because it skews heavily in AMD's favor. If Zen - on average - matches or exceeds Broadwell in IPC I will eat my hat.
lol.Wow, did AMD kick your dog and kill your cat?Did you lose a bunch of money on their stocks or do you just feel animosity towards them just because?
lol.
The question I have is why aren't more people up in arms about this? If Intel or nVidia's marketing programs were as full of blatant lies, obfuscation and deception as AMDs have been for the past several years you would hear the outcry from the South Pole. But AMD somehow gets a pass? Not from me they don't.
wait is everyone expecting 8 core zen and 4 core zen to be clocked at 3ghz? If there are 4 core zen chips I expect them to be running at 4.0 or so. Because no way we have 8 core chips and 4 core chips running at 3ghz. I understand GF might not be able to do too much about 3ghz on first revision but to expect 4 core chip stuck at 3.0 is little too low. I expect 4 core chips to be higher clocked than 8 core as it is always the case.
I think the real problem with zen is going to be glofo. If you look at recent things they've made, they don't clock well. The rx480 has a clock that I have a feeling amd wished was higher. And another great example is apples a9 (6s Soc). The ones on tsmc run cooler and use less power than the Samsung/glofo socs.
The outline is a demo with an engineering sample not a retail product. AMD will shoot themselves in the foot when their retail product can't reach decent clock speeds. Thus this marketing is not so much marketing when it can all still go pear shaped ...All bark, no bite. I'll believe it when they hand out samples, and people start running them vs Intel platforms with nearly the same specs.
Till then... it's all Marketing PR in hopes of making there share holders wet themselves.Reminds me of the slides of "Piledriver" when it then completely failed to get past an i3.
you've been here since 2008? what forum sections are you visiting? lol.. AMD's been on the shit list for the last 5-6 years, there's literally nothing they can do right or wrong where they don't get bashed into the ground by people here.
Yeah, pretty much my conclusion here too. "3ghz" is the only number being thrown around, not "4", let alone 5.
The silver-lining is that maybe it'll panic Intel just enough to overreact and make Kabylake an overclocker's dream, as happened with Sandybridge.
The last time I checked, most of us are still GPU constrained. Heck, there are people still using 2500K CPUs with the very latest video cards. And SB is nearly five years old now. All AMD needs to do is price ZEN competitively and it will do well.
It has to be faster then my 4770 at 4.2 and use less power for me to even think of upgrading.
