Well mine just died after a few months of use. It started last night with the screen going blank while playing GW2. I could tell the PC had not crashed since my other screen was still working. I restarted the PC and the monitor came back on. Then it worked for a little bit. Goes blank and now it won't display anything. Luckily I have another monitor. I think it's the logic board. Anyone know where I can buy a spare? If not, 27" ACD or Dell here I come.
Bigclothcraft asked me how much to put on the invoice and if he can mark it as gift, i figured they would know the answers for those things to best pass through customs without hassle. I guess I have goggling to do.
Tell him yes gift, $100 or $150. It'll save you both customs duties.
here it is...
Alright cool, I found a forum where they said if its a gift there is no fee up to $100 and otherwise its up to $150 so I told him to mark it at $95 if he does gift otherwise mark it $145.
does that also apply for canada?
I just found out if this is correct, In canada there is NO DUTY on LCD screens
http://www.cbsa-asfc.gc.ca/trade-commerce/tariff-tarif/2012/01-99/01-99-t2012-eng.pdf
page 40 (85-40)
I thought there was a free trade agreement between Korea and the US. meaning the extra charges are not needed?
is the 5870 compatible with the shimians monitors? i was going through ebay and one seller had this a list of compatible video cards and 5870 was listed as no.
On the AMD website, it shows that the card (usually depending on the manufacturer, you didn't mention yours) does have dual-link DVI and Displayport. It SHOULD work. After doing a search within the thread, I have come to the conclusion that it will work, BUT that you won't see the BIOS when booting up the system. Whether that will be a deal-breaker for you, that's up to you.
Here's one of the posts I used searching this thread: http://hardforum.com/showpost.php?p=1038979875&postcount=3421
Others will say the same: Next time, do a search.I know it's a very large thread we have here.
I can confirm it that it works. The BIOS screen will not load up, happened to my friend.
But it will work, trust me.
Can anybody confirm they are running this monitor on an ATI card that is said NOT to work, IE 5850, 5870, 5830, ect?
maybe this link can help you http://denbai.com/monitor/q270-main.jpg
see picture at the bottom in vga compatible NVIDIA and AMD
hi all...
there are many videocards that will not work with catleap and others, of this series!
most nvidia cards will, many ati/radeon will NOT work.
that link above leads to a page of images of the catleap monitor and at the bottom is a enlargible image of what cards might not or will work.
mine does not work, the ati 5770!
freestone
hi all...
freestone
hi all...
freestone
You may need a 3 prong power cable, that's about it.when getting this monitor is there any thing that is needed to make things work correctly that doesnt come with the monitor? like cables or anything?
Nice to see that this thread is going strong. My Crossover 27Q was unfortunately one that shipped with a bad LED driver board with the overheating mosfet like this one
It'll work, it's just that you might not see the bios screen at boot up.
