GS, can you type what you read on top of the CPU, the line starting with "ADA3500"?GodSpeed said:Can someone please answer my question above? Thanks![]()
ADA3500DIK4BIiddqd said:GS, can you type what you read on top of the CPU, the line starting with "ADA3500"?
GodSpeed said:ADA3500DIK4BI
CBBID 0451EPAW
$332 CAD + Tax ($267.50 in USD)Dallows said:how much did it cost?
So, that's a good thing right?(cf)Eclipse said:that BI indicates that it's a D0 revision core, which means a winchester
Dallows said:it's a newcastle
GodSpeed said:If it seriously wasn't worth it, please tell me so I can return the chip and get a cheaper one that I can OC better, saving money is always good![]()
not trying to bust your balls, but you're wrong. it is winchester.Dallows said:or maybe I'm wrong, in either case that's a nice price.
Some of us have full time study/work and are starting a home business, I don't get much time on my hands... However I do work on one of the best tech related streets in Toronto so I get good pricing on items and a full week to return anything I buy at said stores on the strip for a full refund. It's worth the chancescott77 said:Blah blah, assumtions
Thanks for the help everyone, esp Eclipse!(cf)Eclipse said:Blah blah, good writting
Viper87227 said:blah blah good plug
(cf)Eclipse said:which sata ports is that raptor on? if it's on one or two, put it on three or four.
and try putting the agp speed to 67mhz.
lastly, try dropping the cpu, ht and ram divider, what's the highest speed your board can go?
MaMMa said:I'm having issues overclocking, and what your saying is fimilair to me.
I have 3 sata drives. 2 hard drives and one DVD Rom.
I have the 2 drives on 3 and 4 and the dvd rom on 1. My agp speed is 67.
I got my Mulitplier at 9 and tried 8. The HTT is 4 and all the RAM is left default ATM. I raise the FSB past 210 and it during boot up it says, "searching for Array" I'm not running any raid arrays and did not use that Floppy disk that msi gave me.
I've got 3 sticks of BH5 pc3500, and it will only work with 2 sticks. (kinda confused on this as well, why can't it take 3 sticks?)
any suggestions will help. Preferably some links![]()
Thank you,
Yo MaMMa
Viper87227 said:Have you tried unplugging the SATA DVD drive? It could be causing detection problems, being out of whack,and it wont let your system boot...best I can think of. Also, with your ram, what voltage and timings are you supplying. I am sure you know this, but BH-5 only overclocks good with lots of voltage. On your issue with booting 3 sticks... I don't know exactly why it works this way, but the more sticks your have the less overclock you get. To my knowledge you can't have 3 double sided sticks of ram at DDR400 ATM....but i could be wrong, maybe its four. Either way, 2 sticks is better. You keep dual channel (even though it doesnt do much) and don't have ram your not using (unless your into multimedia of course, I am saying this from a gaming standpoint). I wish I could better answer your ram question, but like I said I am not 100% sure why it works like that and don't want to give you the wrong answer...i just know it won;t work.
I would be curious to know how the SATA thing goes though. Like i said, try it with nothing on 1 & 2. If that fixes is, your best bet would be to get a SATA PCI adapter card. Should run you about $15 for a cheapo (have the Sybia one myself) and that should allow you to have 4 locked sata ports. If that doest fixx it, try eliminating another drive. Assuming you have a Windows drive and a Storage drive....run just the windows drive and see if you can boot past that. Your case if gunna be one of trial and error, just keep trying different configurations until you get it right.
(cf)Eclipse said:there are also known issues with getting above around 220mhz or so with a raid array, no matter what sata ports you use.
That makes no sense... If you were to use raid that's not supplied by nForce, but by an external IC (Marvell SATA PHY for me) it shouldn't cause problems... it's supposed to run off it's own, isolated high-frequency clock generator, so completely isolated from the main buses in that sense.(cf)Eclipse said:there are also known issues with getting above around 220mhz or so with a raid array, no matter what sata ports you use.
I'm working on it. 2.8ghz stable would be sick. I seem to have hit a wall with the HTT much over 300. Wish I had a 10x cpu multiplier to work with. I am using 2x512MB ram modules, so that may be hindering my overclock some while running 1T. We'll see.......I'll fool some more with it later tonight.iddqd said:Please tell me you can hit 2.8GHz prime stable with a mobile Castle. If you can't, then you just sux at OCing...
(cf)Eclipse said:yeah, not all chips are the same though. if you ask me, the high end of 2.7ghz is quite respectable for a clawhammer that was sold at 1.8ghz
