Shifra said:new to amd, just starting to understand and play with OC.
dabiggoober said:Either you are full of it or live up north and set your computer outside.... Your cpu is at 1 degree. Phase change? Or did you put your computer outside?
Pelt/chiller?Shifra said:The CPU RPMs its registering is actually the secondary 120mm PSU fan, was too lazy to put it into an auxilery at the moment as its a project in the works. And thats not a BS temp and its not outside. There are other ways to cool a CPU internally. I'll edit this with a negative temp when i boot it up.
(cf)Eclipse said:why would he have to buy new ram unless he's going with s940?
i used to use hyper-x in my system. worked quite well. tell him to keep what he has now, it'll work.
Warrior said:hey all im that n00b thats going from p4 to AMD 64..and i would like some one to clarify that PC 3200 WILL in fact work..and be at stock clocks for the running order...i will ofcorse get new ram and CPU later..and i knew if i want to upgrad AMD s where to go... ( my socket 478 is near its limts
Initially, yes. But only the first generation of dual cores. After that, AMD plans to ditch both s939 and s754 at the same time for socket "S1" and "M2".klowngoblin said:DO NOT get a socket 754 for A64, get the socket 939, its the same damn price and it will support dual cores
not really. comparable boards for 939 are still more expensive.groebuck said:Mobo price is comparable - 754 is not dead just dead to the a64 line (sempron still uses it)
please quote where they say that 3200+ ram works up there....R!P13y said:Ok for one they did say that it will work what more do you want man... and 478 socket is dead... intel will never go back to that socket.... A64 is a good shot for the future if you dont want to go PCI e and intels 775 socket...![]()
(cf)Eclipse said:not really. comparable boards for 939 are still more expensive.
k8n neo = ~$100
k8n neo2 = ~140
not as much, but..
epox EP-8KDA3+ = $103
epox EP-9NDA3+ = $113
via is the same way
asus k8v se deluxe = $116 (most expensive asus 754 board usiung via)
asus k8n-e deluxe = $135 (cheapest 939 via board)
i hope you see now that the 939 boards are still more expensive.![]()
Cyberlunacy said:Bravo -
I have almost identicle issues with this Platinum TCCD of mine and its the brainpower 808 pcb which is supposedly the good stuff.
Personally and call me crazy i think this TCCD ram is straight up crap. If a set of ram cant even hold 250mhz fsb without having to run timings so loose that its dumb to run them,, then its worthless ram its no better than any other ram
the 1 and only thing tccd is good for is 200~210mhz at 2-2-2-5 and 210~220 2-3-2-5
frankly anything after that and your putting cas timings into the area of every other single stick of ram on the market except UTT and BH5
for me anything over 250mhz 2.5-3-3-10 causes such massive memtest errors that its impossible to use the ram.
1 run of test 5 in memtest results in over 2 Million errors. and each test afterwards results in the same thing. thats 260mhz 3.0v 2.5-3-3-10
I have a fan blowing directly on the ram, and touching the heat spreader they are VERY cool,, not even warm. very cool to the touch.
Im very much disappointed in this ram, but at this time i can not prove its the ram. I am taking it to work tommorrow and letting one fo the guys take it and try it on his ABIT IC7 Pent 4 system to see what results he gets. I'll then know if its actually the memory or not.
