A64 OC Data
Status
Not open for further replies.
Hey here is mine.
Athlon 64 3200+ Winchester
CBBHD450
1Gig Corsair Pro 4000 3-4-4-8
MSI Neo4 Platinum SLI
271x10 using a Zalman 7000Cu and 166 divider for ram
My X2 4400+ is running at stock so its no help here
LionKinG88 said:
Hi,
Here's my rig:
MSI K8N Neo2 Platinum
AMD64 3500+ (Venice)
Club3D Radeon X800XT
1x200GB SamsungSP, 1x200GB Seagate Barracuda
2x 512DDR 500Mhz PC 4000 Ballistix (Dualchannel)
I heard that there aint any difference if u have 400/500Mhz DDR with AMD64.
Also I heard that there are problems with overclocking if ur using the 1/2 SATA ports.
Is this true or not? :p
That's a good question. I just ordered the same board and a 3000+ venice core A64. Hoping to get a decent OC out of it but had planned to use the first SATA port. Hopefully there isn't a problem... ;)
Dont use the SATA1/SATA2 ports, i wont OC well then.
Use SATA3/SATA4.
Btw I changed my mobo for a DFI LanParty SLI-DR and my videocard for a 7800GTX.
Athlon 64 X2 3800+
ADA3800DAA5CD (crippled Toledo core)
CCBWE 0525XPMW
2 GB Corsair xms twinx 2048-3200c2 pt @ 1T 2,5-3-3-6
Abit AV8 3rd eye
Thermaltake Big Typhoon
2400 mhz (240x10) DDR400 1.375v bios
2600 mhz (260*10) DDR435 1.55v bios
k8n neo2 plat
a64 3200 retail
edit: crummy copper cooler from Best Buy, 80mm fan
CBBID 0501
240x10 VCore 1.50V mem1:1
idle 27C
load37C
260x10 VCore 1.60V mem 5:6
idle 32C
load 46C
memory Kingston HyperX pc3200 AK
2.5-4-3-10@240mhz
Athlon64 X2 3800+
OCS PC3200 Low Latency Platinum PC3200
Abit AN8 SLI
2.6ghz baby!!!
cpu is at 260x10, 1.4v set in BIOS. Ram divider is set to 333 in BIOS giving me DDR433 specs at CAS 2.5 and 2.7v, water cooled with a small copper radiator and low flow pump along with a DD Maze-4 block. Very quiet! I might add a new 120mm radiator though since I am about maxed out on capacity...53c load temps...in a pretty warm room...
Here is what i have so far...im planning on getting a better HSF soon...but this is not too shabby to start...
Amd Sempron 64 2800+ palermo
Default vcore 1.4
Mobo Chaintech vnf3-250
Ram 2 512 of twinmos premium bh-5 at 2.9V
That is a 50% OC...800Mhz more than the default clock of 1600Mhz
Give thoughts...Im currently prime95 torture testing....
Some good data on here, would be nice to get it into a spreadsheet or something.
I've got a 3000+ Venice on the way with a DFI UT-D NF4 that'll post up my OC data...
I found this chart with a lot of good info and posted it in the other sticky thread...
http://www.hardforum.com/showpost.php?p=1028348333&postcount=460
yes - this is stuff which should go into a spreadsheet... hmmmmmmmm... if I get really motivated I might be up to it. :)
3200+ venice
msi k8n Neo 4 SLI
2gig corsair value select
msi 6600gt
rosewill 500watt
2430MHz @1.55v (9*270), 5/6 divider (221 2.5-3-3-8) HTT 4x
looks like i got me a boner cpu
Chris
MoBo: ASUS A8N-E
CPU: AMD ATHLON 64 3200+ (0534) 1.35v@2700mhz
Cooler: THERMALRIGHT SLK-948U(34/36/55)
RAM: KINGSTON DDR400 512mb*2 2.6v@270mhz 3-4-3-5-2T
Graphic Card: ASUS EN6600/TD/256mb 450/550mhz
Hard Disk: WD 250g ATA100
Power: FSP400-60GLN
DVD/RW: BenQ 1640
Monitor: HP L1955
ALTEC LANSING VS-2120
BIOS Setting
HTT *3
my ram sucks, but strong enough...
right now I'm working at this speed...270*10
http://valid.x86-secret.com/show_oc?id=41475
max stable with ram down to 166...280*10
http://valid.x86-secret.com/show_oc?id=41487
pic
thats the highest ive gotten it. the load temps were around 55C and i dont like that, so i have it down to like 2.2 now :/ it was so unstable that i could pretty much just run superpi, everything else would crash. and my a64 tweaker is showing the wrong values in that shot. sorry :/
Everything stable, see sig
Here's the CPU-z Validator Link
Pretty nice OC, I decided to use the devider after I tested it and found that the devider didn't effect anything in terms of performance, but the tighter timings did help, so that's why I did it that way.
darkcrystal said:
pic
What's up w/fan2 in speedfan? 22500 rpm ?
speedfan doesnt report or hte mobo doesnt report SLOW fan speeds proeprly. so when you see that, assume its spinning super slow.
Thought I'd add mine. Can't seem to find too many newcastle's on the forums reporting good oc's.
A64 2800+ (1.8ghz stock) Newcastle @ 2.5ghz, 1.55v to keep it prime stable
278 x 9, 3x HTT
2x512mb corsair value ram, 2.5-3-3-8 @ ~208mhz (3:4)
3700 San Diego, Wrote the code down and lost it. Been gaming at 3001 for a couple days with no problems. But this is the highest running Super PI. ;)
http://webpages.charter.net/tidebill/2976 pi.jpg
nice! I had bet it's a KAB2E... those have very low vcore reqs while maintaining very good OCs. mine only needs 1.4v for 2.8ghz.... I have a feeling it will behave like yours as I approach 3ghz... 1.53v is really good. wow. :)
Yes mine will do about 2.8 on stock voltage also. Something about 3gig just sounds good. :eek:
Cool... when did you pick it up and from where? I got mine from the egg just a little over a month ago. Ya.. 3ghz just sounds [H]ard. ;)
Got it from Newgegg on 9/16. I'm happy with my CPU. :D Got 2 gigs of Ballistic last week. I'm so happy I'm looking at new cases now.
Nice... I would be willing to bet $ it's the same stepping and possibly week/batch (0532XMPW) as mine. :)
Got an Opteron 146 today (1mb cache, 2.0Ghz stock).
Running at 2.9Ghz at the moment, on a stock FX55 cooler (I broke the opty's stock cooler when installing it :eek: ).
3Ghz is pretty unstable. Prime fails after about a minute, and 8M super-pi fails, but at 2.9 it's rock solid. I might see about getting a better air cooler... or I could put it in the vapo :p
man where did you get that chip, I really want to get a chip that does 3 ghz.
x2 @ 2750Mhz
both cores prime stable
watercooling only the cpu
I haven't tested further :cool:
Got an Opteron 148 (2.2) Venus core yesterday with the following specs:
CABYE 0543FPMW
OSA148DAA5BN
1352979K50192
Does anybody know if this is a good week/stepping? Can't find much info. Thanks. :)
WHOA! I was thinking about buying an FX55 claw from a friend and seeing how well it's OC'd... do you think I could get 3.1 out of it on water with 1.6 vcore?
I followed the A64 OC'ing guide and got these (unimpressive) results for an OC:
HTT went only to 255
Cpu went to 2634
Memory (3 sticks) will only boot at 3-3-8, only up to 230MHz
So for a final OC I'm at 2627 cpu, 219 HTT 1:1 memory. See sig for specs.
Comments?
Venice 3200 LBLLE 0516 EPGW
so far 2650 ghz 1.575 volts
ram is 1:1 no divider
running on zalman 7000b
47 load super pi prime 52 load.
idle 30 cool and quiet on 33 idle CnQ off
Status
