Yeah, do not jump on the reference 980Ti unless you absolutely MUST HAVE IT NOW, and/or you play on headphones/do not care about noise level.
I like a silent build, so I am waiting for some good non-reference designs. My current video card has the same TDP as 980Ti and the cooling in Gigbayte OC is quite good, on a customized fan profile the card reaches 83 C under load with around 50% fan speed, which is not too loud, and there is not much throttling (core is over 1GHz).
I think that is wrong.
I just got two reference models.
I have them overclocked to run 1400 MHz under load (GPU clock + 185) with no voltage increase and the fans running at 65%.
I can run this card all day at this load and the temperature is 70-72C.
The fans are barely audible, and honestly just blend in with the case fan noise.
My intention is to watercool them as soon as there are Heatkiller blocks available so to be able to up the VCore and see what these cards can really accomplish.
That said, these latest NVidia reference coolers are about as good as you can ask from a single fan reference cooler. They beat what any other brand has to offer without question.
I agree with magoo. As long as you don't touch voltage, which doesn't buy you much anyways, the nVidia reference models stay pretty quiet.
Ref 980 Ti is about the same noise level as the ref 290X.
You people are craaaaaaaaaazy.
lmao "Quiet"... My sides.
Here's my results of my 980Ti SLI cards running at 1545/8000
Firstrike extreme: http://www.3dmark.com/fs/5046796 Good for #23 HOF 2x GPU
Firestrike: http://www.3dmark.com/fs/5045751 Good for #58 HOF 2x GPU
Those are some serious clocks. What's the secret?
I don't understand this generation obsession with quiet GPUs. Last time I checked, GPUs only get stressed when under load from gaming which, if I remember correctly, tend to have audio.
I don't understand this generation obsession with quiet GPUs. Last time I checked, GPUs only get stressed when under load from gaming which, if I remember correctly, tend to have sound effects and music playing.
Didn't realize so many people game with their rig sitting on their desk next to them with the exhaust pointed at their ear. I've never had a reference card loud enough to bother me. My 780 SLIs definitely don't put out anything loud enough to distract me from gaming and it sits under my desk next to my feet with upside down orientation on my case so all the exhaust blows upwards. Just seems like so much fuss over nothing.
Didn't realize so many people game with their rig sitting on their desk next to them with the exhaust pointed at their ear. I've never had a reference card loud enough to bother me. My 780 SLIs definitely don't put out anything loud enough to distract me from gaming and it sits under my desk next to my feet with upside down orientation on my case so all the exhaust blows upwards. Just seems like so much fuss over nothing. And this coming from someone that gets pissed off at coil whine. I guess my home has great noise cancelling accoustics or my speakers are just that good.
You haven't heard a loud card until you've used a gtx480 or 290x with a reference cooler.![]()
You keep answering your own question... Citing old cards and how loud they were and then questioning why newer cards with better and more efficient technology are more desirable seems strangeI did experience the 480 woes, that thing was a unique piece of hardware.
But i didn't think the 290x was that bad for the week or so I used it. Maybe I just have good ambient temps. My little 8800GT was louder than 99% of the cards I have used in the last 6 years.
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_980_Ti/30.html said:Unfortunately, NVIDIA has been sloppy in their implementation of the GTX 980 Ti's fan settings. The card does not stop its fan in idle or light gaming. While it is very quiet while not loaded, that's not good enough for many low-noise gamers. The same happened with the GTX Titan X, I wonder why.
During full-on gaming, the GTX 980 Ti is very audible as its noise output slightly exceeds that of the Titan X. Our Titan X sample runs its fan at 48% (=2300 RPM) and the GTX 980 Ti runs the fan at 50% (= 2380 RPM). Here the GTX 980 Ti is again too noisy, not following the trend. Sorry, this is not 2013 anymore, and NVIDIA's own fantastic efficiency improvements brought forth this age of super-quiet high-end gaming cards with such exemplary products as the ASUS GTX 980 STRIX and MSI GTX 980 Gaming; the GTX 980 Ti is not one of them. To me, it looks as though the cooler is a bit too weak to handle the heat, so NVIDIA had to turn up the fans. I do have high hopes for custom-board designs, which should definitely reduce noise levels.
The rumor now says that the card will see word between 19th and 26th May... which is logic choice for NV, as it's Witcher 3 release date. So people who will want to upgrade their old hardware to play Witcher, will get something new and shiny.
I know it's too good to believe, but I'd like very much it to be true. After upgrade to 1440p, my single 970 is not enough to play everything on max, and I could use upgrade. Don't want to go to 2nd one because of VRAM issues, and 980 is rather sidegrade.
Its pretty loud when overclocked but its actually not all that rough or whiny sounding. The reference gtx 470 I used was way louder and much more annoying sounding even at stock clocks. Still though I think I may return the reference 980 Ti for a non reference card.db charts are soooo useless. I need to hear the type of noise!
The Asus Strix GTX 980 Ti will likely hit the market in late July or early August.
http://www.kitguru.net/components/g...sified-kngpn-edition-engineered-to-overclock/
King Pin Looks really nice copper and Black with extra Vent holes on the front.
custom bios running at 1.28v.
watercooled max temp of 38c.
No secret, just a lot of money invested and a lot of luck with 2 great cards.
I can game all day on these. I lower it to 1540 for 24/7 since 1550 locks in benchmarks due to not enough voltage. No artifacts or crazy crashes etc. I can't get these things to crash if i tried and I have tried everything under the sun for hours on end.
This is the one that is supposed to be available on June 16th?
Awesome. I plan to WC mine too. Did you make the alter the bios yourself or download one? I might have to look for one.
Glad to hear you can do so well with reference board circuitry
