Southparkrocks
- Aug 12, 2005
Since it works with the jetway board, it should work with the evga board right?
I bit for 2 Gigs ($119 shipped), will test with Springdale 865 chipset when they come in.
so_cal_forever said:Grrr, I cant figure out if my MSI K8T Neo FSR supports high-density chips... Nothing in the manual about it.
kirbyrj said:I'm pretty sure most Via chipsets work with this RAM. That is a Via chipset right?
qbackin said:Works with Asus A8N sli deluxe??
sabrewolf732 said:what makes these chips less compatible than others? aren't all 1GB sticks 16 chips? If I send somebody a $130 mo will somebody order them and send them to me? I don't got paypal heat under this username
I don't know what dram idle timer is -- I don't have anything in the timing section that takes a value that high. I have a DDR Clock Delay setting that takes values from 1-6 CLK's. I also have a 2T Command setting that sets to Auto, Enabled, or Disabled that I haven't touched yet.Nettwerk said:Try dram idle timer at 256
trc = 7
trfc = 16
No dice. My TRFC only goes to 15, so I tried that along with 7 for TRC. The PC wouldn't even boot, I had to clear CMOS.Malatov said:I don't know what dram idle timer is -- I don't have anything in the timing section that takes a value that high. I have a DDR Clock Delay setting that takes values from 1-6 CLK's. I also have a 2T Command setting that sets to Auto, Enabled, or Disabled that I haven't touched yet.
I'll try the TRC and TRFC values you mentioned though. I had to flash back two BIOS versions to get my memory settings back. Since I generally ran at stock timings before I didn't notice when they disappeared. I'm surprised Asus would take that away in recent BIOS versions. Any other ideas are welcome too!
Thanks.
That is one ugly stick of ram you got there
Ryan711 said:anybody tried 2 of these on a Asus A8V Deluxe. LMK cause i'm probably going to order tomorrow. Thanks.
Rev. said:Anyone try 2 of these on a DFI UT nf3 250 GB?
