DarkenReaper57
- Oct 2, 2003
Does anyone know if this stuff works with a MSI K8N Neo2 PE? If so, how well?
you have to comb his entire inventory for stock updates and make sure you don't keep clicking OP's original linkFindarato said:Good lord this guy sells out fast
Nforce4 motherboards deemed worthy in this thread:blurhahn said:so it has been confirmed without question that it works fine in nforce4?
i'm seriously considering this...but i'm not sure if it will work in my mobo...Chaintech VNF4 Ultra
Yes and yes edit: but ymmv as always. Lots of info spread about in this thread, just gotta dig.Thuleman said:Was anyone able to run this memory at 2.5V?
His auction specs say 2.5V. Curious about whether it would be possible to run 2.5V and t1.
The shipping charge makes me angry.
csm11 said:Just to give a little update about performance upgrade I experienced. I play Half-Life 2, Counter Strike Source, and Battlefield 2 and they all run great on Athlon XP 3000+, Gigabyte 7VA, 2 gigs of this ram, and ATI 9600 pro (not oc'ed). I run HL on highest settings and Source on highest settings. I run BF2 on mostly high settings except for a couple of them like geometry and other shading settings. Just to let anyone know it was worth the $113 to get the 2 gigs...
mine came usps first class, it was here to indiana in 3 daysShodin10k said:I just ordered some... i was just wondering if they sent any tracking to the people that ordered, and how soon it came into your possession.
I read through a bunch of his negative ratings and he is apparently pretty series about replacing defective product.Pkirk618 said:ships nicely in padded envelope. No reason so far not to put a little trust in this one. If you don't get it to work, i think he has a return policy.
Malatov said:Well, I normally only buy solid name-brand memory, but after seeing all the positive results here I pulled the trigger on 2GB worth. I don't see any specific results for my Asus K8V SE Deluxe (S754 K8T800) but according to the manual it will run two 1GB modules with up to 18 chips at DDR400, so I'm assuming that means it will run high-density. If it doesn't, I've got a few Linux boxes I can spread it around in hopefully.
When I get it I'll post results for anybody else who might be wondering...
so_cal_forever said:New ebay link, still a few left on the old one, but only for 49 more mins at posting:
http://cgi.ebay.com/BRAND-NEW-1GB-P...ryZ74942QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I fail to see a reason behind the shipping going up each time...
NF2 typically doesn't like high density memory.Megadeth_Guy01 said:no nForce 2 results yet
DarkenReaper57 said:It works with the NF3 chipset, right?
Same chipset, have to keep an eye on your results.Shodin10k said:i think its because people are catching on, and hes having to do more work
when i get the memory, ill test it on my msi k8t (k8t800)
honkee said:if someone has the memory and doesnt want it, ill buy it for 60 shipped
Nay.2k2_zx2 said:So is it a yay or a nay on this stuff in an NF7-S V2.0? Got 2x256 that I wouldnt mind upping.
Pete84 said:Nay.
