Your Internal IP Scheme
Discussion in 'Networking & Security' started by [BB] Rick James, Dec 2, 2007.
  1. [BB] Rick James
    [BB] Rick James [H]ard Dawg
    2,818
    Apr 4, 2004
    What is your internal IP scheme? I have a buddy that runs 81.181.0.1/255.0.0.0.
    what do you run? Right now I'm running the following
    172.30.0.1/255.255.0.0 and 10.0.10.100/255.0.0.0.
    what is your internal scheme?
  2. Xipher
    Xipher 2[H]4U
    2,621
    Mar 15, 2004
    Is your buddy in Romania?
    % Information related to '81.181.0.0 - 81.181.0.255'
    inetnum: 81.181.0.0 - 81.181.0.255
    netname: SC-SYNCO-MEDIA-SRL
    descr: SC Synco Media SRL
    descr: Intrarea Barsei 6, Bl. G7, Ap. 76,
    descr: Sector 3, Bucuresti, Romania
    country: ro
    admin-c: LO343-RIPE
    tech-c: LO343-RIPE
    status: ASSIGNED PA
    mnt-by: AS3233-MNT
    mnt-lower: AS3233-MNT
    mnt-routes: SYNCO-MNT
    source: RIPE # Filtered
    person: Lucian Obrocea
    address: Intrarea Barsei 6, Bl. G7, Ap.
    address: 76
    address: Bucharest,
    address: Romania
    phone: +40788608238
    e-mail: lucian@syncomedia.com
    nic-hdl: LO343-RIPE
    mnt-by: SYNCO-MNT
    % Information related to '81.181.0.0/24AS34565'
    route: 81.181.0.0/24
    descr: Synco Media
    origin: AS34565
    mnt-by: SYNCO-MNT
    Tell your friend the RFC1918 address space exists for a reason, DON'T GO OUTSIDE OF IT.
  3. [BB] Rick James
    2,818
    Apr 4, 2004
    Settle down there big shooter, He is behind a router nad NAT'd, pretty sure he isn't killing anyone by using that scheme.
  4. jeffmoss26
    jeffmoss26 2[H]4U
    2,267
    Aug 1, 2002
    I use 192.168.1.10x/255.255.255.0
    All static IP addresses
  5. [BB] Rick James
    2,818
    Apr 4, 2004
    Why static everything?
  6. jeffmoss26
    jeffmoss26 2[H]4U
    2,267
    Aug 1, 2002
    Well I use remote desktop for most of my computers, and I have several routers for testing, so I just give everything an IP.
  7. Xipher
    Xipher 2[H]4U
    2,621
    Mar 15, 2004
    No, but he will notice problems in the case he attempts to connect to any thing else with in the netblock he is using. In the off chance any thing leaks outside of the NAT his ISP might get pissed thinking he is trying to spoof. My biggest point here is don't just use what ever the heck you feel like especially if you don't understand the consequences. Hope he doesn't try and use 65.52.0.0/14 down the line.
  8. rogue_jedi
    rogue_jedi [H]ardness Supreme
    4,834
    Sep 6, 2002
    192.168.1.x/255.255.255.0
    Addresses below 10 are static, everything else is dhcp.
  9. Grentz
    Grentz [H]ard as it Gets
    17,154
    May 5, 2006
    I always stick to a 192.168.X.X scheme. Right now I am using 192.168.0.X.
    Some of my machines are static (servers) and the rest are DHCP. I switched to 0.X because 1.X tends to be what routers and network devices default to thus screwing things up if they get connected. On 0.X most things do not default to it and thus wont screw with anything if they do get connected.
    and yes it is not proper to go outside of the guidelines even if it is for internal. The problem is 1) you will not be able to connect to anything in that netblock (for example if you used 75.126.99.XXX you would have issues connected to hardforum) and 2) as said if it leaks out it could cause some issues.
  10. O[H]-Zone
    O[H]-Zone [H]ard|Gawd
    1,465
    Mar 28, 2003
    10.0.0.10 - 10.0.0.255 (255.0.0.0), static for the server(s) (under 10),
  11. RoBo
    RoBo 2[H]4U
    3,533
    Jan 5, 2007
    192.168.2.XXX
  12. YeOldeStonecat
    YeOldeStonecat [H]ardForum Junkie
    11,330
    Jul 19, 2004
  13. Xipher
    Xipher 2[H]4U
    2,621
    Mar 15, 2004
    I should probably contribute
    Currently every thing is in 192.168.0.0/24, how ever I intend to do some more work and eventually break off wireless onto a different subnet.
  14. SmokeRngs
    SmokeRngs [H]ard|DCer of the Month - April 2008
    15,416
    Aug 9, 2001
    Everything is set for static IPs with DHCP disabled. Why? Because of the need for port forwarding and using VNC for some of my systems.
    Also, I keep DHCP disabled. You'd be surprised how many people you can stop trying to access the wireless due to disabling DHCP. That's on top of disabling SSID broadcast as well as WPA2 encryption. I prefer to be paranoid. Plus, you don't need to know if I have wireless going unless I allow you to use it.
    Also, I have a certain way I prefer to have my IPs setup and keep certain ranges for certain systems. Wireless IPs use a different range than wired. This has less to do with any type of security than it does just being able to easily figure out what is what. If there is any type of problem, it's a lot easier to figure things out with everything separated this way.
    [​IMG]
  15. Mak
    Mak Limp Gawd
    150
    Oct 14, 2005
    192.168.0.0/24
    Servers and VNC stuff reserved via DHCP
    everything else DHCP
  16. dbwillis
    dbwillis [H]ardness Supreme
    7,255
    Jul 9, 2002
    172.16.1.x for me
    192.168.x.x for my customers that I service
  17. Qualm
    Qualm Gawd
    562
    May 31, 2003
    10.0.1.x/24 for the servers in our colo;
    192.168.104.x/24 for the office servers and workstations;
    192.168.204.x/24 for test (browser compatibility, etc.) workstations NAT'd behind a DMZ router outside our VPN tunnel.
  18. IHateYou
    IHateYou n00b
    31
    Nov 19, 2007
    192.168.0.XXX. Static IP's for everything. Makes port forwarding simpler.
  19. TechLarry
    TechLarry Can't find the G Spot
    30,022
    Aug 9, 2005
    I think we played this recently. Here goes:
    Routers/Switches - 192.168.0.1 thru .10
    Servers - .10 thru .19
    Printers - .20 thru .29
    Workstations - .30 thru .39
  20. Milenko
    Milenko [H]ard|Gawd
    1,482
    Jul 15, 2002
    192.168.1.xxx / 255.255.255.0
    static IPs scattered below 100
  21. Fint
    Fint [H]ard|Gawd
    1,046
    Jun 11, 2004
    127.0.0.1/24
  22. Xipher
    Xipher 2[H]4U
    2,621
    Mar 15, 2004
    Fint, I find that that one might be a bit difficult to get functional, with the loop back interface and all.
  23. Jaffa Cakes!
    Jaffa Cakes! Limp Gawd
    136
    Oct 13, 2007
    10.0.1.x/255.255.255.0
  24. Dew
    Dew 2[H]4U
    3,826
    Jun 23, 2003
    10.10.10.1/24
    3 subnetworks, one dhcp server, 4 internet connections.
    10.10.10.1 = Router/DHCP/2 internet connections(IP based load balancing on RV016)
    10.10.10.11 = Router/1 internet connection/DHCP disabled
    10.10.10.21 = Router/1 internet connection/DHCP disabled
    Total machines on network: 24
    10.10.10.10 = Primary Fileserver (2TB)
    10.10.10.20 = Secondary Fileserver (2TB)
    10.10.10.5x is reserved for xbox 360s (5 of them) (static DHCP)
    10.10.10.8x is reserved for one room
    10.10.10.9x is reserved for my personal machines
    10.10.10.10x-254 is DHCP
    The entire IP range is blocked from net access, rule exceptions are made for machines that need on the net.
  25. Captain Colonoscopy
    Captain Colonoscopy 2[H]4U
    3,862
    Feb 19, 2004
    Home is 10.169.254.0/24
    clients are setup on 172.16-31.x.0/24 networks. I like to go class b subnetted out to class c.
    [​IMG]
  26. WesM63
    WesM63 2[H]4U
    3,276
    Aug 29, 2004
    At home i use 192.168.20.x/24, simple and effective.
  27. mctwin2kman
    mctwin2kman 2[H]4U
    2,370
    Jul 3, 2001
  28. Chiggy
    Chiggy [H]Lite
    84
    Nov 23, 2003
    10.100.100.0/24 at home
    10.0.0.0/8 at work
  29. InorganicMatter
    InorganicMatter I Don't Know How to Make Threads
    15,249
    Oct 19, 2004
    1-15 are static, dynamic goes up through 100. I run static on pretty much everything.
  30. zmjone2992
    zmjone2992 [H]ard|Gawd
    1,034
    Jul 3, 2007
    modem is 192.168.1.xx
    router is 192.168.2.xx
    static ips >100
  31. svet-am
    svet-am [H]ardness Supreme
    5,149
    Jan 6, 2003
    My setup is 192.168.123.xxx where 192.168.123.120->192.168.123.125 are static and assigned to workstations. 192.168.123.190->192.168.123.200 are dynamic for friends and guests that come over. 192.168.123.245->192.168.123.250 are "infrastructure" devices like our file server and print server. The netmask is old faithful: 255.255.255.0
  32. Verge
    Verge [H]ardness Supreme
    6,060
    May 27, 2001
    172.16.355.0/255.255.0.0
  33. swatbat
    swatbat [H]ardForum Junkie
    12,845
    Apr 25, 2001
    Internal at home is 192.168.10.x as I set it as that years ago and never bothered to switch it due to having to reconfigure some printers and whatnot.
    Clients have them in class a b and c ranges.
    Family office is 193. something which I've never bothered to fix as I don't feel like screwing with the unix servers. Some jackass through it in the public range like that 15 years ago before the machines were online and the consultants that have installed the 2 new servers and software over the years have left the range like that as they didn't want to screw with the legacy server at the time. Kinda agree with them as it hasn't caused any issues yet...
    New networks I tend to throw into the 172 range.
  34. Motley
    Motley 2[H]4U
    2,441
    Mar 29, 2005
    lol nobody caught that one...
  35. [BB] Rick James
    2,818
    Apr 4, 2004
    So you loop around to your self hu?
  36. ndruw
    ndruw Limp Gawd
    247
    Mar 7, 2006
    This man is entirely correct in his thinking.
    also, i'm on good ol 192.168.0.* until i get back home
  37. [BB] Rick James
    2,818
    Apr 4, 2004
    It's a lot of extra work when you could just keep up todate on your security and just reserve stuff in DHCP. If you take your laptop anywhere you have to f-around with changing it all back.
    Waste of time, secure yes, but a waste of time in my eyes.
  38. brom42
    brom42 2[H]4U
    3,996
    Mar 1, 2004
    Home
    Wired: 172.24.32.0/255.255.255.192
    Wireless: 172.16.24.0/255.255.255.192
    Work
    Servers: 192.168.4.0/255.255.255.0
    Users: 10.250.0.0/255.255.0.0
    Terminals: 172.16.32.0/255.255.255.0
  39. TechieSooner
    TechieSooner [H]ardness Supreme
    7,612
    Nov 7, 2007
    I don't personally do this, but I do see the advantage in certain situations...
    Static IP addresses you can map to a physical location. Bandwidth slump? Bam, find the IP address, look at your chart- instantly know who it is and go see what they are doing.
    I'd say in most situations static IP Addressing is tougher though.
    Heck, 90% of people couldn't connect.
    And of those that know they need to set a static IP, they have to know your schema or (possibly) be unable to connect to anything on your LAN itself.
    I personally also use the 192.168.0.X range. I have everything above 192.168.0.100 DHCP. Anything below that is phone system, routers, etc.
    People that set this up before I started working here addressed things in a crazy way. One printer is at 192.168.0.52, another at 192.168.0.125, just crazy (Would break too many things to change now).
    Generally, though...
    192.168.0.1 is router.
    192.168.0.2- 192.168.0.10 is servers
    192.168.0.11- 192.168.0.33 is various devices (routers, VPN tunnels, etc).
    Phone people have their own IP addresses around in the 192.168.0.50-192.168.0.59 range... I don't touch anything in there.
  40. Icidic
    Icidic n00b
    59
    Mar 17, 2007
    1.1.1.x for Internet Placeholder (WAN)
    10.0.0.x for Local Area Network (LAN)
    10.0.1.x for Demilitarized Zone (DMZ)
    10.0.2.x for Wireless Network (wLAN)
    and also a OpenVPN Network to Network Link to a 10.10.0.x network :).
