MGMCCALLEY
[H]ard DCOTM SEP 16 / NOV 17
- Jul 3, 2012
Ok, I'll let it chug along this weekend. Maybe it will help. Good luck.
We have identified the issue and are working on the clean up process. Once we have everything cleaned up we will restart sending out work omitting the batches that have the problem.
Thanks,
armstrdj
We are getting ready to restart sending of MIP1 work. The batch numbers that had the bad input files were in the range of 4783 - 4872. We have done what we can to prevent any more of these from going out. Thanks for everyone's patience while we cleaned this up.
Thanks,
armstrdj
Interesting observation; but how can I influence the mix off assignments ? Sure, I can open up again to other WCG sub projects (I just did as the current method not getting new HSTB WU in at all). So let see if a mix of MIP and HSTB improve the runtime.ChristianVirtual, I think the long run times may be caused by running so many at the same time. I've seen similar behaviour on my 4p. A normal run time for 2 or so concurrent HSTB monster tasks is normally under 12 hours on a Ryzen.
These are some results from a Windows 1800X @ 3.7GHz.
free-dc.org quit updating my stats 11 days ago, my stats still update on the WCG site, and other people are getting updated at free-dc...weird
