- Dec 16, 2006
2.6GB downloaded of the 64-bit version.. then i got cut off... =[
freon, can I have the x86 key?![]()
I would gladly give it to you if it weren't for my test system being x86. I was just trying to get the 64 key in case I decide to give it a shot on my main.
36 seconds till my d/l of the 64bit version is done and my 1.4MB gets returned to the bandwidth pool.
Ahh make it done now.
Does anyone have a MD5/CRC type checksum so that I can check the integrity of the file?
Thanks Steve for the direct links...you're an angel!!!!!!!
do you need a product key? and how long can you run this os?
Haha no worries. I will just have to be vigilant and patient as I sit here running Windows 7 thinking preeeeetttttyyyyyy. And fast. And NIS09 works. But Windows Update doesnt.
it will be fine..I have it on a 2Ghz system also ...(XP3500) with a Gb or ram and its every bit as fast as my quad core vista box.....sadly enough....I'm curious about the speed. I am initially going to be running it on an older system; Athlon XP 2Ghz.
Issue - Windows Update ain't workin in Windows 7. Anyone else installed and having this problem? Help doesn't connect to online as well.
my d/l finished in just under 2hr. with firefox. and no issues. Go figure!
Oh, and I didn't have any major problems with it... got it yesterday, (x64 version) installed this morning to an SSD drive actually..
