I was a 3090 Launch Day F5'er who signed up for an eVGA notification at 9AM EST.
Look what UPS just brought me....
Sony cassettes? Amazing! LOL
Speaking of Sony Cassettes,(Segway) that reminds me of what a 3090 looks like...they are both rectangles.Sony cassettes? Amazing! LOL
nice. You might want to add another intake fan though. Looks like you only have the single front intake, which with the rear fan plus the fact that the 3090 exhausts some heat directly out of the case, you have a negative pressure situation, even if you don't have top exhaust fans, which would be more negative pressure. Basically it just means your CPU fan is pulling air, but from no direct path, so pulling from wherever it can get air, not necessarily through a fan filter, which will lead to more dust in the case.Founders edition, runs quiet and cool.
System power peaks at ~580W, so a 750W Gold PSU should be good enough if you don't run a monster CPU. Mine is a 9700F.
Good point. Only have two of these corsair fan and I'm hesitate to add more fans because want a quiet PC. So far it's been manageable and runs quietnice. You might want to add another intake fan though. Looks like you only have the single front intake, which with the rear fan plus the fact that the 3090 exhausts some heat directly out of the case, you have a negative pressure situation, even if you don't have top exhaust fans, which would be more negative pressure. Basically it just means your CPU fan is pulling air, but from no direct path, so pulling from wherever it can get air, not necessarily through a fan filter, which will lead to more dust in the case.
If he has any more problems he can send me the 3090 for free troubleshooting.My friend ran into issues with games crashing a few minutes into playing after installing his 3090. There would be an audible hum or coil whine. He was running a Corsair HX750i, which should have been enough, but it was bought in 2014. I swapped it out with a Corsair AX1200 PSU and now he no longer crashes or has the audible whine. I should have taken some footage in case people are trying to troubleshoot similar issues.
Wow, that's crazy. The HX750i is a top quality PSU, too.My friend ran into issues with games crashing a few minutes into playing after installing his 3090. There would be an audible hum or coil whine. He was running a Corsair HX750i, which should have been enough, but it was bought in 2014. I swapped it out with a Corsair AX1200 PSU and now he no longer crashes or has the audible whine. I should have taken some footage in case people are trying to troubleshoot similar issues.
but you ordered after me
What did you have to do for it?Decided to go to Microcenter today before work and snagged a 3090. Feeling dirty now.
I just walked in and bought it, nothing moreWhat did you have to do for it?
Idk if I'd get rid of my 3090 or not in thst case. I have down some deep learning workloads that push it right to 24gb, and maxed it out in unreal engine as well. But $500...I think the upcoming 3080 Ti is gonna make the 3090 look like a very bad value buy. I'm betting it comes in at $999 with 20GB. But you know... at least you have 4GB more RAM with the 3090 for just $500 more.![]()
Or you just want it for the he’ll of it. I seriously thought about it just because- my friend does ML work on his, mine would just be gaming, but... nah. Gonna be happy with my 3080It was always a bad value buy and then you add on the AIBs $100+ extra. Right now there's an EVGA FTW3 3090 being sold for "Cost" in the FS threads at $2025. It's absurd that a card that is 10-15% better than a "$699" FE card is $1300 more. You're never going to get that kind of value out of it unless you do real work on it.
No kidding! Meanwhile I have a 3090 and can use it. People that own 3090s generally don't care about the price. They want the best. Let me know when the 3090 Ti is out!I think the upcoming 3080 Ti is gonna make the 3090 look like a very bad value buy. I'm betting it comes in at $999 with 20GB. But you know... at least you have 4GB more RAM with the 3090 for just $500 more.![]()
they should do a 3090x2, now that would be somethingNo kidding! Meanwhile I have a 3090 and can use it. People that own 3090s generally don't care about the price. They want the best. Let me know when the 3090 Ti is out!
I actually think resale value of the 3090 will be ok. These cards have uses outside of gaming. Never thought I'd pay less than $400 to own a 2080Ti for two years either.... but here we are.
If the 3060ti actually launches on the rumored dec 2nd date, then I'll have some faith a 3080ti might actually show up. Until then, it's fantasy.Yeah, where I am going with my small concern is the rumor of all of these versions slotted throughout the portfolio - i.e. 3070 Ti, 3080 Ti - plus the larger memory versions. NVIDIA always knows how to squeeze a buck out of everyone, so maybe my worries are unfounded.![]()
Man, close to giving up on this 3080 hunt crap and just getting a 3090!
Here in Europe they are indeed easier to get. Well not impossible to get is the right way to put it.Like a 3090 is in stock somewhere?
