Which Motherboard for 8700k? Do I wait?
Discussion in 'Motherboards' started by vidoprof, Jan 10, 2018.
  1. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    So my current Rig will do OK for me for a bit (~3 months). I am a photographer / Videographer.
    Current setup
    i5-4570
    16gb ram
    Asus Z87
    850SSD (OS)
    WD Black 4TB for data and editing (Photoshop, Lightroom, Premiere Pro)
    I AM buying a 960 EVO 1TB - NVME which will def help with editing (and I can transfer to a New Rig when I build it in 2-3 months)
    My question.. Do I build NOW (I CAN) or wait for 2-3 months (I can wait also) I know you can't predict the future, but best guess.
    Motherboards are the biggest issue for me as they are ALL over the place and SOO many models and options.
    What I need in a new rig:
    (1) m.2 PCIe NVME slot (scratch, Cache, Projects) for Editing (I will have the drive)
    (1) PCIe x16 (I know they all come with it) since I will be running (1) GPU most likely a 1060
    (4) DIMM slots (32gb ram)
    (4) Sata ports (don't need Raid)
    (4) USB ports (preferably 3.0, why is 2.0 even a thing anymore?)
    Maybe Wants:
    Wifi - 2x2 - I would LOVE to have wifi as my router is a good distance from where the computer is going to be.
    (1) Thunderbolt 3 port
    (1) usb-c port
    (1) Dual Nics (I have a synology 1812+ and would love faster connection to it - would that help?)
    (1) m.2 slot (future expansion of drives)
    So do I wait? Any reason to build now? IF SO... What motherboard would be the cheapest best option for what i need (I KNOW not much in the need category).
    p.s. I am ok with a MILD overclock if it's SUPER easy and doesn't require an expensive cooler.
    Am I missing anything else you might want to know to help make a decision?
    Thanks
    Ryan G
  2. jacuzz1
    jacuzz1 [H]ardness Supreme
    6,840
    Feb 14, 2004
    Talk about coincidence. I just made my decision and went Ausus Tuf Pro gaming since i had such success with my Sabertooth and its the closest thing. I serious considered the EVGA board but at the time it was not available so i pulled the trigger. I am building the rig today and tomorrow as time permits. I will let you know my thoughts once i get it all together. I had bad experiences with Asus wi-fi so i was not interested in those offerings.
  3. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    I would love to hear your thoughts for sure. Did you NOT go with a WIFI board? Which EVGA board were you thinking about? I don't even know where to start... I don't want to look at every board on the planet. That might take a while.
    Thanks
    Ryan G
  4. RazorWind
    RazorWind 2[H]4U
    3,041
    Feb 11, 2001
    I would assume he means this EVGA board:
    https://www.newegg.com/Product/Product.aspx?Item=N82E16813188189
    I have no experience with it, but EVGA doesn't make any junk.
    How about something like this?
    https://www.newegg.com/Product/Product.aspx?Item=N82E16813119032
    That has nearly everything in your want list, except for the dual nics and thunderbolt. There's also a non-wifi version. I'd probably go with that, and just use a USB or PCI-E wifi card, which can be had for like $7.
    MSI offers the "Godlike," which I think has everything you listed, but it costs $500.
    https://www.newegg.com/Product/Prod...4104&cm_re=MSI_Godlike-_-13-144-104-_-Product
    vidoprof likes this.
  5. jacuzz1
    6,840
    Feb 14, 2004
    That right, My rig is hardwire.
  6. Furious_Styles
    Furious_Styles Gawd
    939
    Jan 16, 2013
    I'll be interested to see what he thinks as well. I personally think the TUF series is not up to par anymore and want to see if he agrees. There are a few boards that seem close but they are all 200+
  7. jacuzz1
    6,840
    Feb 14, 2004
    Well I booted her just now. Clicked XMP on the ram and went into windows at just under 5GHz . Just under 1.4v on the cpu. 26 c with a Nactua U9s The board build quality is very good. It is not as heavy as my Sabertooth but its still good. I have to do some cable management, batton everything up and then tomorrow I will start put it through its paces. The EVGA looks real nice. I was pissed that they sent me an available notification after I ordered this but I am pleasantly surprised so far.
    By the way, these 8700's are smooth as a babies arse.
  8. Batboy88
    Batboy88 Limp Gawd
    326
    Dec 25, 2017
    Don't go with Asus, it's shittt. and will quit on you...
  9. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    Thanks for those links man. I really appreciate it. I guess I have a little more research to do. I DO NOT want to spend $500 on a MB.. I just won't use it. I DO NOT plan to overclock much and well I don't have a TON of needs.
    Ryan G
  10. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    What are you mainly doing with your rig? Gaming? Keep me posted please. Looking forward to hearing more. Wondering what kind of speeds you are able to maintain.
    Thanks.
    Ryan G
  11. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    Thanks for the reply.. but I hope for Jacuzz1 it doesn't quit out on him.
  12. newls1
    newls1 2[H]4U
    3,940
    Sep 8, 2003
    MSI Z370 Gaming Pro Carbon is about the best z370 board ive used to date. Just sayin. So much love on these forums for Asus, and Others, but MSI is almost always overlooked. Had both an Asus and Giga 370 board variants and 1 had ram issues and other couldnt get my cache up to a respectable speed. MSI nailed it on both front with slightly less voltage.... So coming from someone who has had actual experience with 3 different companies offerings, I c an vouch for MSI Pro Carbon hands down.
  13. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    Thanks so much for the heads up man. I really do appreciate it.
  14. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    AND it's cheap
  15. jacuzz1
    6,840
    Feb 14, 2004
    My nephew has had issues with MSI so i avoid it. Asus has always been good to me except thier onboard Wifi . I had absolutely zero issues with my Z87. It is the best board that I have ever had. If do not sell it, it will become a workstation and a gift to my son when he graduates as an automation engineer. I use the machine for work and gaming. I am about to try it out now with a little Battlefield.
    PS: I would be remiss if I did not inform you that currently AI Suite is crashing due to a Windows update issue so I have no health monitoring until there is a fix. Anyone no of a free progy for system temps?
  16. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    Any reason to NOT get the MSI Z370 Gaming Pro AC board? It IS mATX but it seems to have everything I need. Is the overclocking not as good? I don't plan to overclock beyond the absolute basics. Whatever the BIOS will get me without too much stress (as I tend to keep my rig for 4+ years).
    So any downsides to getting the m-ATX board?
    Thanks
    Ryan G
  17. jacuzz1
    6,840
    Feb 14, 2004
    Do be honest, i did not even look at it. Perhaps I should revisit MSI some day. It just that Asus and EVGA have been very good to me.
  18. SixFootDuo
    SixFootDuo [H]ardness Supreme
    5,174
    Oct 5, 2004
    Get the Asus ROG Hero Maximus for $235
    fantastic board, best firmware updates in the industry, high-end sound with build in DAC, overclocking prowess unmatched by any other board manufacturer.
    There is an wifi AC version for an additional $35 or so dollars.
  19. kirbyrj
    kirbyrj Why oh why didn't I take the BLUE pill?
    23,471
    Feb 1, 2005
    I've used the Asus ROG boards (Z87 and Z170) and MSI Gaming Pro Carbon (Z270) and other MSI boards (couple different Z77 and Z97s) and all of them are excellent boards. I'm currently using a Gigabyte Aorus (X299) and have used Asus Strix (B350) for AMD. All of these boards have worked without issues and overclocked my CPU's to the limit of what was reasonable to expect for the CPUs. My experience has been that Asus tends to put out more regular bios updates, but I wouldn't NOT buy any of those brands if you find one that meets your specification requirements. I didn't have a good experience with EVGA motherboards, but that was on a much older Z68 board.
    Batboy88 is just spewing bullshit (again). Probably best to put him on ignore.
  20. jacuzz1
    6,840
    Feb 14, 2004
    Just finished up gaming at a hair under 4.8 gz Smooth, very smooth in Battlefield. Board rock solid so far.
    vidoprof and kirbyrj like this.
  21. newls1
    newls1 2[H]4U
    3,940
    Sep 8, 2003
    the gaming pro ac is NOT a mATX board... they do make a version that is mATX and I think even a ITX but the z370 Gaming Pro Carbon is NOT mATX... Full size ATX board
    https://www.newegg.com/Product/Product.aspx?item=N82E16813144107 DAMN AND ITS ONLY 159$
  22. jacuzz1
    6,840
    Feb 14, 2004
    Nice board, is it just me or do they all look like they were made at the same factory and then rebadged lol.
  23. kirbyrj
    23,471
    Feb 1, 2005
    It looks almost identical to the z270 version.
  24. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    So did you let the board do the overclocking or did you do it manually?
  25. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    Maybe I meant uATX.. Sorry. The Gaming Pro AC is uATX.
  26. deaedius
    deaedius Gawd
    829
    Jun 18, 2014
    The two Z370 boards that do seem to go head to head is Asrock Taichi and the Gigabyte Aorus Gaming series.
  27. jacuzz1
    6,840
    Feb 14, 2004
    I have it set to auto / normal and she boots to 4.4 boosting to 4.8. If I manualy choose the xmp profile. she boots to 4.8 and if I set extreme auto she hits 5gz but I am not comfortable there since the board applies 1.404 volts. The BIOS reports 32c at that speed but without my health monitoring software working, I am not sure what the temps will be under load. I'm going to wait until i get it working.
    KUDOS to Noctua air cooling and these new chips are magic, this one runs cool. Sorry about the typos using voice to text (fixed) I was on the road.
    Once I get AI suite working I will really delve in. I don't want to fly blind
  28. jacuzz1
    6,840
    Feb 14, 2004
    Party time, I downloaded a version that I found on that Asus provided for the Maximus board, i then deleted the set up file from it, dragged and dropped the setup file along with the .dbin from the CD. I opened the system information application exe from the cd and ran that. I then ran the modified AI Suite 3 executable. It worked ! I am able to get real time health information now. I am going to boot to 5gz and play some Battlefield
  29. jacuzz1
    6,840
    Feb 14, 2004
    tenths of a megahertz below 5 with auto set to extreme tuning. 1.402 v and 73 c. while gaming. I think this chip could really fly with liquid cooling. and a little rocket science in manual mode. I will leave that for down the road after the novelty of every day 4.4 GHZ at 1.24v and 60 c under load wears off.
  30. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    4.4 at 60c is a nice position to be in. I guess now I might as well start looking at building. I was debating just buying Dell though spec'd out with a 5 year warranty.. Probably come really close to most of the components and they would have to fix them when they break in the first 5 years.
  31. jacuzz1
    6,840
    Feb 14, 2004
    Idle in XMP profile 1 on air turboing to 4.859GZ or thereabouts. I tried to get the screenshot as it fluctuated but it's hard to do. These chips have alot of head room.
  32. Aluminum
    Aluminum Gawd
    549
    Sep 18, 2015
    I would wait but...
    Not exactly everything but pretty close so I'm going to plug this one here: https://www.asrock.com/mb/Intel/Fatal1ty Z370 Gaming-ITXac/
    Thunderbolt, usb-c, wifi, intel nic, overclocker stuff, etc and it still all fits on ITX.
    You can get 32GB with 2x16 in ddr4 just fine, and it clocks pretty high on intel imcs that are not as picky about dual rank or chip type as long as its not bargain bin.
    Dual lan will not speed up your NAS to any one system, need faster ports on both ends. I doubt it actually can get close to 1GbE on anything but sequential anyways.
    You could add 10GbE using the thunderbolt port though it ain't cheap, or you can link to other TB3 computers with the virtual nic which is cheap.
  33. jacuzz1
    6,840
    Feb 14, 2004
    3dmark.png lol
  34. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    Nice... I WILL NOT have a 1080Ti, nor anything more than a 1060 (probably a 1050Ti) since I don't benefit from anything beyond that.. but those are good numbers.
  35. jacuzz1
    6,840
    Feb 14, 2004
    She is built so that my son and I can game and I will also use it for work.
  36. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    Gotcha.. yea I don't game at all. Good thing you got that card when you did.. I hear the prices are through the roof.
  37. jacuzz1
    6,840
    Feb 14, 2004
    Mine is available for 1,200? lol
  38. JNavy89GT
    JNavy89GT [H]ard|Gawd
    1,753
    Apr 25, 2001
    I have really liked my past few Asrock Z170/Z270 boards. I get the Fatality gaming K4/6 series. I think the new Z370 gaming K6 looks good. No wifi(get the Taichi if you really need it), but IMO find a way to run a hard line as all my Wi-Fi experiences have me going back to NIC/LAN as soon as I can. Of course that is for gaming etc... For surfing and work stuff WiFi is fine I guess.
    Speedeu4ia likes this.
  39. vidoprof
    vidoprof Limp Gawd
    406
    May 3, 2007
    Thanks for the heads up. I appreciate it.
