There are Vista x64 torrents. I don't want to link to the sites though. I saw 2 yesterday.Rehevkor said:There is no torrent for the 64bit version. Winbeta doesn't have it either.
Sorry then, I see 3 very active ones right now.Rehevkor said:I found a couple of dead links, and maybe one that's an earlier beta, which I have no interest in. I haven't seen the public beta 2 anywhere.
The key will install Vista Ultimate on the ISO. I believe all features are in the beta. Things are bound to change between now and the final release as far as functionality of course.fallguy said:I read a little of this thread, but didnt see my answer. Does this build have everything that will be in the final? Ive downloaded it.. and got my key, just want to see if its worth it, or if its just a stripped down beta.
Blue Falcon said:Does anyone know how long the beta will run after installation before it expires? I can't seem to find a definate answer on the CPP site for vista.
Downloading the 64-bit version directly via the 'use my own download manager' link with no problems. Maxing out my 6mbit connection in fact, at this rate it will be less than 2 hours total download time.
pxc said:The key will install Vista Ultimate on the ISO. I believe all features are in the beta. Things are bound to change between now and the final release as far as functionality of course.
Hito Bahadur said:Couldn't get X64 version to burn correctly to DVD. I think there was an error somehow in the download...
fallguy said:I am using DVD Decrypter... working fine so far, almost done.
me too.Crosshairs said:Thats what I used...worked like a champ..
use a winxp disc or somethign to make sure its allready formatted into NTFS. I ran into the same problemfallguy said:Burned fine, but wont let me install to the HD I want. Its clean, empty, and lots of room. Ugh. Its dynamic.
I did the quick format, and it worked. I dont think thats your problem. does the installation give anymore clues?fallguy said:I formatted it, via quick format first, to NTFS. Didnt work. Doing it again.. the slow way.. takes forever on a 300gig HD.
dbwillis said:Is it because "Backup2" is Dynamic ?
nst6563 said:yes. You cannot install Windows on a dynamic disk. Convert it to a "Basic" disk with a primary partition and it should work just fine. (at least with Windows XP)
...damn...I did learn something from those M$ exams
iRoNeTiK said:I got the link off MS website to work for me. I downloaded DAP 8, Download Accelerator Plus 8 and then I right clicked the link and picked "Download w/ DAP" and then hit start download and it worked like a charm
Elios said:any one know if i can "upgrade" my XP64 install to the Vista 64 beta 2?
Blue Falcon said:You ought to be able to do that just by popping the disc in and following the upgrade wizard that comes up. I wouldn't reccomend this at all though, a clean install is much much better.
list your system specs...fallguy said:Gave me a blue screen during install. I think it had an ati error message, could be wrong. I was on the couch, across the room when it was installing.
it will recognize your SATA...maybe not RAID though.Cannydog said:I also used a download manager / accelerator to get it. It went quite well, possibly the first time I've seen my system do a sustained download at 6Mbit.
But I'm definately making an image of my current OS install before I try to install either of these (I downloaded both the 32bit and 64bit versions). Because I expect problems, for instance the ULi southbridge on my motherboard isn't exactly 'industry standard'. I guess I"m off to find drivers for that... I don't think it will even recognize my SATA drives without drivers.
Chris_B said:People running x1800 or x1900 radeons might want to be careful btw, i was running hl2 lost coast and noticed the fan wasn't spinning up or down while playing it. Not sure if that means it was staying in 2d mode or went to 3d mode but without the fan adjusting itself.
