I have a question about the panel on the vp2770 for anybody that might be around:
http://imgur.com/jwT91Am
(sorry about picture quality, but I am using a cheap digital camera that I don't really understand how to use)
On a black screen, I can see horizontal lines that seem to cover the entire panel. My poorly taken picture might make those horizontal lines seem like artefacts from overexposure, but that's essentially what I see on the panel. They kind of look like static scanlines.
They are most visible on a black screen, but even on dark greys (like the background of hardforum) they kind of look like a static filter over the whole screen.
Is this normal, or does my panel have a problem?
(There's also some light backlight bleeding on the bottom that isn't very noticeable unless viewed up close. It's slightly visible in the middle of that picture above.)
Edit: If it matters, I tried over DVI, DP, and HDMI and the different interfaces didn't seem to make a difference.
I currently have the monitor connected via DVI, and I believe I took the picture after I settled on DVI.
Using DVI because I hooked back up my other monitor (dell u2713hm) with DP.
I don't believe it's a problem with the graphics card (290x) because those lines don't appear on the dell.
