skudmunky said:Total Sweetness! How does the stock Tt water cooling run? Is it worth the extra 100 ish for it to be included?
DarthBeavis said:Thermaltake Armor with BIgWater SE and Aquabay Resevior/Flow Indicator/Radiators. Used DangerDen 78 GPU block.
AMD X2 4800, 2 gigs Corsair, 500 gig HD, Geforce 7800 GTX 256, Armor 2 case of course,
PC Power and Cooling 510 with UV green sleeves, Dual Dell 2001fps.
I built this for the wife. She dose not even game. . .LOL
http://img207.imageshack.us/img207/231/dsc00317custom7xl.th.jpg
http://img83.imageshack.us/img83/4760/dsc00326custom3qw.th.jpg
DarthBeavis said:Does it run better on its side?
You are an over-clocking God. I bow to you.SpectralFx said:Dropped 5 degrees at idle....wonder if I could drop more upside down.....![]()
No because the fan is blowing up, not down. The way I look at it is the fan in the front is pulling air into the case, the bottom fan is picking that up and pushing it through the Ninja, and both the rear fan and PSU are pulling the hot air out.SpectralFx said:Are you having any issues blowing hot air from your oc'd processor right on to your graphics card?
crpav said:I would like a nicer looking resevoir because I am all about looks. Possibly a better pump too. The water block is high quality in my opinion. All in all it is very nice as it is and my temperatures are running about 10 degress C cooler.
I hope you are not serious...DarthBeavis said:You are an over-clocking God. I bow to you.
elite.mafia said:I hope you are not serious...
seems like you should paint the mobo tray the opposite of the case interior; so for example, if the inside of the case is red, paint the tray black, and vice versa. if your case exterior is mostly black, you should up the main interior red and the tray black, IMO, and also do the same to your drive cages, to sort of balance the effect. that'd be pretty spicy.the gamer said:I want to paint the inside of my Xaser III case, I'm going with a Red/Black style (red neons etc etc) but I dont know if I want the motherboard tray Red or Black, Red would make it more stand out, while black will make it more stealthy sorter thing.
the gamer said:jakindle looking good.
Just got to get the money to do it.
jakindle said:
Yes I meant the whole side and since the motherboard is on it I just called it an Motherboard Tray.98EXL said:I have a XaserIII case.....I don't remember a MoBo 'tray' or do you just mean the whole side of the case? Flat blacking the inside is so hot, I did it to my brother's PC, looks good, told a friend to do it on his armor, looks hot, gonna do mine once the modding begins in a few weeks.
inside flat black = the new black
yes, I am obsessed with it
yea i didCereal Killer said:did you paint the inside? it looks awesome.
