The Verge Ridiculed for "How We Built a $2000 Custom Gaming PC" Video
Discussion in 'HardForum Tech News' started by Megalith, Sep 15, 2018.
  1. DrLobotomy
    DrLobotomy [H]ardness Supreme
    5,606
    May 19, 2016
    Someone should arrest this guy and the parent company sued for lying to the public.
  2. primetime
    primetime [H]ardness Supreme
    5,600
    Aug 17, 2005
    they wont pull it lol.....cause they likely dont even understand any reason to pull it
  3. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    You failed logic 101, right? Or you somehow believe fake it till you make it? Or you are invested in hardware companies and want idiots building them so more products will be sold to replace where they destroyed them? Please elaborate your logic for us, because I hate to break it to you, but knowledge is power, and you are saying just try with no knowledge. Do they let anyone who wants to "get out there" perform brain surgery? Rocket surgery? Please, do tell!
  4. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    It's like other things in life, someone learns from someone that doesn't know what they are doing and then it goes to spider web from there. The worst is people that argue that they are right and there are four or five other clueless people to make you wrong even though you are right, because "majority wins."
    chaos4u likes this.
  5. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    It's obvious but I'll say it anyway, that is a surefire way to destroy your RAM at least and probably the board too if you get too aggressive. The video that keeps on giving...
  6. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    It's like lots of things in life, such precision, you know exactly the torque required. Not a single question remains...
  7. Joust
    Joust 2[H]4U
    2,745
    Nov 30, 2017
    There's a lot of tolerance for thermal paste. I saw a video of someone that used none, too little, and way too much. Actually has suprisingly little impact.
    I usually do a peasize in the middle, one solid seat and no gaps. Works for me, though I'm sure there's plenty ready to flame over my technique.
  8. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    Use this knowledge in all aspects of your life, square peg, round hole, POUND 'ER IN.
    c3k likes this.
  9. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    I used to use the peasize, until I removed some of the ones I did and saw where there was no paste. I now put a thin even coat with a credit card or such. Works well you might want to try it.
    It can vary, depending on the hardware. For GPUs they seem to usually have a lot of paste on there. I have seen CPUs that had too much paste thermal throttle or even shutdown. With the newer CPUs it's not as much of an issue. I've seen debate on this for probably close to 20 years. One thing is true, if you put too much and it oozes on the board, pins, or components, it will cause problems.
    Armenius, dvsman and N4CR like this.
  10. trparky
    trparky Gawd
    975
    Jul 23, 2009
    I did too.
    Armenius likes this.
  11. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    It's like a lot of things in our information age, alway double and even triple check, and sometimes you will see something that is so wrong it's like a what NOT to do video. It's your job to check and make sure the "expurt" is actually correct.
  12. bsoft
    bsoft Limp Gawd
    268
    Jul 11, 2004
    I spent most of the video wondering why they didn't tell us which CPU they used (other than "hex core" that "supports overclocking").
    It turns out, you can actually see it in the video:
    "Intel Confidential"
    The S-Spec code corresponds to an 8700K, which would make sense, but for some reason they are using an engineering sample?
    babochee, GoldenTiger and N4CR like this.
  13. Ocellaris
    Ocellaris Ginger @le, an alcoholic's best friend.
    18,795
    Jan 1, 2008
    Bruh, you gotta realize that no consumer CPU can handle League of Legends. They had to use a special engineering sample from Intel Skunkworks to hit 120 FPS :eek:
    Armenius, dvsman and GoldenTiger like this.
  14. IcePickFreak
    IcePickFreak [H]ard|Gawd
    1,093
    Dec 1, 2010
    Maybe he needs the headroom to stream instructional videos on LoL next. :eek:
    Armenius and GoldenTiger like this.
  15. Skylinestar
    Skylinestar Limp Gawd
    484
    Jun 14, 2011
    He's definitely an Apple sheep.
  16. opfreak
    opfreak Gawd
    759
    Nov 17, 2005
    That's why after I build my PC I vacuum seal it. Keeps the smoke in ;-)
    Armenius, N4CR, triwolf and 2 others like this.
  17. Jim Kim
    Jim Kim 2[H]4U
    3,416
    May 24, 2012
  18. dark_reign
    dark_reign 2[H]4U
    2,187
    Nov 15, 2005
    Aside from the numerous mistakes, he could of took the time to do some proper cable management. Anyone with $2000 to burn and sees this embarrassment of a build will quickly walk away.
  19. DOhZ2
    DOhZ2 n00b
    4
    Jan 5, 2016
    There is simply no excuse for this video. Sad. Very sad.
    mbelue, dvsman and triwolf like this.
  20. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    That makes sense, and not much in the video did, so essentially look at the video as what not to do. It's the anti-'how to build a PC particle' that destroys the 'how to build a PC particle.'
  21. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    I would support a citizen's arrest. Or at the very least, someone take the thermal paste away from this guy. Who was it that told him to add more paste to an already pasted heatsink?
  22. UrielDagda
    UrielDagda 2[H]4U
    2,844
    Nov 16, 2004
    AHHHHHHHHHHH!! That video hurts my brain.
  23. triwolf
    triwolf Gawd
    708
    Dec 19, 2015
    I'm usually a person that can take somewhat annoying things, but listening to more than about 5 seconds of this guys voice it's like fingernails on a chalkboard. He's got some major league sibilance going with those s's. Sorry, have to put volume to lowest possible I can hear. The video is comedy gold otherwise.
  24. dark_reign
    dark_reign 2[H]4U
    2,187
    Nov 15, 2005
    If you couldn't get enough of this cringeworthy build:
    triwolf, dvsman and Ranulfo like this.
  25. staknhalo
    staknhalo [H]ard|Gawd
    1,204
    Jun 11, 2007
    How many jiggawats does it have?
  26. nysmo
    nysmo Gawd
    945
    Jan 7, 2016
    stopped watching after he accused builder of improper ram installation. While *most* boards use an A/A B/B setup I've personally had a board or two that was A/B A/B. Also the fact that he's trying to nitpick on PCI lane bandwidth when he's installing a video card that will have no other options other than to use the highest bandwidth lane anyway due to form factor I'd say the real cringe is probably in all the responses calling the verge out.
    N4CR likes this.
  27. Deimos
    Deimos Gawd
    953
    Aug 10, 2004
    Why? RTFM; ROG STRIX Z370-G Gaming manual was shown in the video, that board states B2 A2 installation for dual channel operation when only 2 dimms used.
    I built my mother-in-law a cleaner PC than this garbage. I'm tempted to post pics...
  28. Derangel
    Derangel [H]ard as it Gets
    17,541
    Jan 31, 2008
    Not "most" boards, damn near ALL OF THEM. I doubt there is any gaming-grade motherboard from the last decade that has a 1-2 or 3-4 dual-channel set up, especially from Intel. I can't even remember that last time I've seen a board that isn't 1-3 or 2-4. Hate to see what the dumbass in the video would have done if handed an enthusiast grade board.
  29. Deimos
    Deimos Gawd
    953
    Aug 10, 2004
    Here is a tip I haven't seen anyone mention; Leave the plastic cover installed on the retention mechanism, DO NOT remove it by hand. Instead, lift the retention clip, install the CPU, then drop the retention clip (with the plastic still installed) on to the CPU, then clamp down and the plastic cover pops off. Once the plastic pops off, you can safely use your grubby mitts to grab it and put it away for safe keeping. I started doing this after one time my cocks for fingers removed the plastic cover then immediately dropped the cover on the socket pins and bent them, this was immediately after receiving the repaired motherboard after an earlier bending incident FML. I did it right in front of the technician who was showing it to me, fuck I felt like a dolt.
  30. M76
    M76 [H]ardForum Junkie
    9,028
    Jun 12, 2012
    Yeah guys, the verge did a fantastic job, there is nothing to see here, move along...
    /s
    This is supposed to be an educational video, so the advice uttered is not meant for this exact set of components only. So saying it doesn't matter which slot is a mistake. I wish that was the biggest mistake in the video.
    I've never seen such a board in my entire life. The only boards that are 1-2 are the ones with only two dimms.
    So basically what you're saying: Don't do it properly let the cpu pop it out, because you're clumsy?
  31. motomonkey
    motomonkey [H]ard|Gawd
    1,419
    Jan 17, 2009
    Definition of journalist
    1 a : a person engaged in journalism; especially : a writer or editor for a news medium
    b : a writer who aims at a mass audience
    2 : a person who keeps a journal
    Per Merriam- Webster.
    So, yes, anyone who fits "1.B" above is a Journalist.
    So by That definition the guy on You tube who eats ghost peppers and chases it with Fireball is a Journalist. He’s documenting the effects of Long term Alcoholism, I suppose.
    If that doesn't fit in with some people's notion that you have to have a degree and be employed at a brick and mortar media establishment, well to bad. I guarantee some of those Youtubers make more money than this idiot spreading peanut butter on a CPU.
  32. naib
    naib [H]ard|Gawd
    1,263
    Jul 26, 2013
    Exactly "tie wraps, wtf are they... must be a spelling mistake, I mean these are geeks that wrote this. Must mean Tweeters"
    Everything about this was scripted and executed by someone with no idea except finding the right face for their video. It couldn't have been vetted by anyone who really knows
    I would question this.... the statement about no TIM ... The point of the TIM is to fill in the voids between the two mating surfaces
    Will it work? sure but the thermal resistance will be higher... Now maybe the surface of those instances were "smooth" enough.
    This is why I either put a pea blob in the middle and slowly tighten up going around each corner in turn to allow the paste to be squeeze out OR I take a razor and spread it thinly.
    Saying that though I am tempted to go for graphite sheet for the next time I change my CPU as this stuff has ridiculously low thermal resistance and is easy to handle PLUS will maximise the heatsink usage due to the x-y characteristics
  33. Joust
    Joust 2[H]4U
    2,745
    Nov 30, 2017
    I should be clear: Use. Thermal. Paste. No way am I advocating not using it in a generally accepted application method / quantity.
    Maybe I don't recall the video correctly - I tried to find it again but can't seem to. Perhaps it was only too little, too much, Goldilocks.
    That said, I am of the opinion that the best thermal transfer would be achieved with perfectly machined mating services.
  34. naib
    naib [H]ard|Gawd
    1,263
    Jul 26, 2013
    And that is correct. If there was a convenient way to cold weld then you would get an almost ideal interface
  35. capt_cope
    capt_cope Gawd
    895
    Apr 12, 2009
    Ok I watched the video... I'm 90% certain it's just troll bait - There was editing done, and even someone who knows nothing about building a PC would have caught the whole "tweezers" bit. Same goes for the swiss army knife instead of a screwdriver - there's no reason for that UNLESS they're just trolling people.
  36. TheOne&OnlyZeke
    TheOne&OnlyZeke 100% Irish
    10,221
    Jul 21, 2000
    Ha this is brilliant. Has to be a troll video. There is SOOOO much wrong with this, it just has to be there to draw viewers to boost rating
    Fuck...we are all contributing to it by just watching the shit
  37. Nightfire
    Nightfire [H]ard|Gawd
    1,533
    Sep 7, 2017
    Idea for a comparison:
    Build one system identical to this, missing screw, single channel memory and all, then compare to a properly built system with the cheapest 2133 mhz in dual channel and a properly cooled i7 8700 (non-k). I bet the 2nd system does better while saving over $100.
    Armenius and triwolf like this.
  38. Dullard
    Dullard 2[H]4U
    2,207
    Jun 28, 2012
    In its defense, The Verge has only recently lost its technology editor.
  39. Motley
    Motley 2[H]4U
    2,452
    Mar 29, 2005
    I just saw yesterday browsing youtube and watched a bunch of tech tubers analyzing the verge video. What is a Verge, never even heard of them. They sound like a bunch of tards, either that or as some of you said they are trolling for traffic. If they are trolling for traffic, wow even worse.
    If its a troll video, then Linus Tech Tips got rick rolled?
    Either way, we should all notify Capital One basically wasted the money on this crap. Nobody do business with the Verge, and nobody watch their channel. How in the fuck did they get 2.1 Million subscribers. Thats a lot of 12 yr olds.
  40. evt
    evt Limp Gawd
    251
    Apr 6, 2006
    The video is now gone!
