Just work hard and try like hell at everything you do and you'll be surprised what you can obtain.
but I quickly figured out that the harder I worked, the harder I could play.
Here you go...
Behind Clouds
My laptop as of today...time to work on my desktop.
However,I do think I need to find another wallpaper though. Too bad 4scrape is no longer available...
http://img87.imageshack.us/img87/193/desktopbg31082009.png
That's nice toobookoo. I'm finding it harder and harder to use multiple colors in my desktops
Thank you very much sir.
Where did you get the wallpaper from? Would be great for my fujitsu
What config are you using for the weather? Is it just the normal HUD Vision one? Fore some reason HUD Vision weather won't work for me since I began using Windows 7. The Enigma MoxaWeather config works for me. Not sure why the other one doesn't. A couple others I tried didn't seem to work as well. Just that one. Hmmm.
http://forum.notebookreview.com/showthread.php?t=25730
Still using HUD. Works fine for me. Sometimes it disconnects and I have to press F5 on the desktop to see it. Are you using a firewall?
must share wallpaper!!!!!
The one for my laptop at the moment.
Any word on the icons you're using in the screenshot? I asked in this thread AND sent you a PM...but no answer in either....?
Current wallpaper after using a Megan Fox one for a little bit.
On another note, does anyone else that uses the stack docklet with rocketdock have a problem where one of the stack docklet's keeps losing its icon settings? In my case, every now and then, the icon settings for the PRGM stack docklet gets reset and I have to put the filepaths there again. None of my other stack docklets have this problem.
Actually, I used to have that problem. It was very annoying. If you move/delete the docklet that keeps disappearing, then another docklet will have that symptom. It was always the first one in the dock for me. Annoying. Tried setting admin and file control and everything recommended. Gave up and so then I went to Standalonestack.
ygpm lol...
Though I have nothing against Apple or its users, I though this would go over well on this board.
*snip
