How in the hell do you beat the Warrior?
I mean really, I'm at level 30 and my ass gets kicked every time.![]()
was cultivating a goliath that had a loot chest strapped to himself. he became an ultimate badass then started jumping at those stupid whirly birds. jumped right off the map....![]()
As much as I'd hate to give myself a bad name... but I found the Warrior to be easy too. Lol.
I did exactly that got onto a pillar and sniped his chest. A explosive shotgun works good too. I have one that does 540x16.
I completed every side mission (including both arenas) in PT1 and was only level 44 against Warrior. I don't think 3-4 levels will make the battle unwinnable. He probably just had the wrong approach.
when you select your character from the main menu it should ask you which mode you want to play in
All I have is a small item in the upper right with my user name and the level number by it.
On the left hand side is the typical menu.
If I click on this user name, it says "profile" and that's it......no mode choice?
I have got killed more often by trains then I have by mobs![]()
Every time I get a golden key I get grenades... and if there is one thing I don´t need from that chest, its purple nades! FFFFFFFFFFFAARRRJJJKKK just needed to vent.
Apart from that the game is still awesome. Can not wait for them to raise the cap.
You can make a new char, then switch to it. After that go back in, reselect your leveled char and it should prompt you for which mode you want to play.
guess what... I GOT NADES, useless purple nades! AGAIN! is this a bug.. I want a gun of some sort, bastards lol
For those complaining about golden chest items, it's actually harder to find good items then anyone gives the chest credit for.
I did a little experiment and replaced my .bin on a throwaway level 20 for 255 keys.
I would say 1 in 25 keys actually drops something worth keeping, no joke. Not only that the chest works in a very narrow field of values, always giving out the same dps value guns in differnt flavors (bigger clip or elemental or small clip and faster fire rate). Also that's if your even lucky enough to get a gun, more then half the chest openings give worthless class mods and grenades.
It's the biggest inside joke in the game, in 30 minutes of farming anyone can easily get something twice as good and not obsess about twitter feeds.
Just my 2.
Just my 2.
