I’ve used another Lian Li case, I have no doubt in its the good quality. However the price is very high. One third to one half those prices would be a lot more reasonable.
The filter is inside the red rectangle.
You can see the extra plastic layer right?
Will have to buy a V700 with black internal and window and the regular V700 black w/o a window and combine the two and sell the regular one with the window.
Fails without a 3.5inch slot for card reader.
Just finished a build. All of the really detailed information can be found on the OCN thread here. Also, sup exodu5, why'd you get banned from GAF? We miss you in the PC thread.
You've got about 165-170mm (could only measure from the 'thermal armor' on the motherboard) of clearance. Should be fine.Got banned for this. Eh, I deserved it. Ban is up in 4 days.
Thanks for your impressions of the case. Can't wait to get mine. Kind of sad the H100 can't fit. I'm really, really hoping my Thermalright Venomous X fits, as I won't have to buy a new cooler if it does.
TBH, surprised you went for this over the TJ04-E. Sweet case though, perfect for a single card air build.
Would be worthless using the scythe 12mm one, they have zero static pressure.thanks for the information michalius. so if I replaced the left fan with one of these it'll fit?
The Yate Loon medium speed 120x20mm does *okay* on a radiator. It still depends on your exact motherboard for clearance though. Even then, you'd probably get better temps putting two really nice 120mm fans on an H80 in the back.
So will the Corsair H100 fit this case?
I have the Corsair 800D which I find a bit too big for my needs and I am planning to switch to the V700 soon.
I have H100 and Rampage IV Formula motherboard.. will these fit properly inside a V700? I'd like to keep the H100, if possible..
The H100 will not fit with the Lian Li V700 (and most likely by extension the V750) as it conflicts with the 8pin power plug, at least with the Asus Maximus V Gene that I intend to buy. I never owned an H100, but I loved the H80 I used to own, good on temps and noise with dual upgraded fans, and it works with more case designs. This makes the H80 my new favorite now as the H100 is just too dam picky about placement. Or rather most cases are not designed for it. But the biggest news is I just read that the V750 is apparently now an all 120mm fan design:
http://www.lian-li.com/v2/en/produc...x=612&cl_index=1&sc_index=0&ss_index=0&g=spec
I hope that is not a typo, as I thought the V750 had a 140mm in there somewhere. It looks like venting is present with a filter on the floor just under the GPU area. Perfect place to add another fan for GPU cooling - this case will be the bomb with 7 x GT AP-15 fans and an H80![]()
Mmmm. Retina Macbook Pro or desktop gaming beast?
As soon as someone confirms whether the H100 will fit without any clearance problems in the new PC-V750 post it here.
Until Mac updates their products with current gen hardware on a consistent basis, the PC desktop will always be king.
Just get both. iPad/Macbook + PC desktop. Best of both worlds. Portability or power when you need it.
