jonneymendoza
- Sep 11, 2004
ahh sweet can they be used for the pc a70 ?
Is there a hole cut in the case divider that we can't see, or is that Zalman CPU cooler's air intake starving against a metal panel?
I'm still working on the sidepanel / window, and my lights just arrived. Pics will follow =)Another fellow V1200b fan...very nice Any other pics..i.e. daytime, outside of case..etc.
is it me or is it missing a video card?
its a nice case, but with the front of the case completely sealed with no vents, exactly where is the fan blowing air towards? or sucking air from? if its just recirculating the same air in the case, I'm afraid it'll be high temps.
I don't know about you, but whatever AUX is on SpeedFan doesnt look so happy. 122C sounds really really hot, thats like 250F+.the case has some openings in the base in front of the fans. and no high temps:
Btw, do anyone have idea how to get fingerprints of the black aluminium computer case ? Seems like impossible task![]()
xveganx where did you get those black cable ties that looks like it clues to the case?
I've found that Windex works really well. Spray a little on, wipe off with a soft washcloth or rag...makes LL black cases nice, clean, and shiny.![]()
Finally built today! Thanx to everyone....
who helped me pick out hardware and made suggestions, to make this my best rig ever.
Q6600
Zalman CPU Cooler
Corsair 620W HX Power Supply
EVGA 8800 GTS (512)
G Skill PC800 DDR 4gb 2x2 dual channel ram
WD Raptor
Dual Samsung DVD 20X SATA Burner
Lian Li Multi Card Reader
Lian Li. PC-60 Plus
this is my first post on any website ever. i just put this together.
If u mod the rad to fit on top of the case .. u still have the HDD cage to be used ..
if u would like to mount the rad at the bottom then get Lian Li HDD Cage EX-34/33 which could fit into the rom slot by occupying three slots and left one for the DVD-ROM...
