The Lian Li Gallery
I'm comPLETELY sold on the S80...being able to leave that top access plate installed is a godsend...and while the hard drives are fairly exposed, there's nothing stopping me from leaving the lower access panel installed, and cutting a window in it AND the main side panel that only encompasses the mobo area, not going any further right then the side of the HDD "rack".
Lian-Li has done so many things right with this case...I'm completely in love with it...and I know I could do great things with what they're offering in the S80. :D :cool:
Everyone likes more pictures. Here are some more of my case:
And there is room for a 3x120mm rad up top. The top is only single wall construction too with a little bit of foam insulation on the top. I was thinking about adding a 2x120mm Aqua Computer Evo up there and water cooling the whole thing, but air is simple and I'll leave watercooling for my other computer.
Very nice pics (again) Aqua...I LOOOOVE that case.
It's nice to see that the front panel of the case behind the door is nice and flat so it'd be easy to cut ducts into it for those front 120mm fans.
Aside from that, can you let me know whether or not the door itself is flat? I generally don't like case doors, but if it's flat enough it'd be simply to cut a large "window" in the door to fill with some honeycomb mesh, and then cut those two ducts for the front intake fans.
Very awsome case overall...so elegant and has so much potential. :D
Yeah dude, that does look really nice, but where do the front fans get air? It looks like that thing has two front 120mm fans, but from your pics I can't for the life of me see where they would get any fresh air!
For those of you with the PC-G70 Lian Li case, how does air get into the front fan? It looks like the front panel would restrict quite abit of airflow into the fan.
Should I plan to go ahead and plan to cut a hole on the front plate (add a grille/filter/etc) to help get more air in?
I am planning to buy this case within the next month or so and was just wondering.
Link to Lian-Li's Website for more info
The door is flat, but is has 2 sheets of metal on it for double box construction. You could remove the entire door itself and the brackets, they are connected with some screws you could easily undo.
stormshadow said:
my next project:
LL G50
Hellou
I own Lian Li V600 in Black. Im curious what do you plan.
I made a little modding with my case. I make a hole for 92mm fan between the PSU and motherboard at the bottom of the case. This fan blows fresh air right into the CPU area. The PSU fan is oriented to suck air from the outside of the case. Fan spins are lower and sound level is lowert too.
Every 12cm fan I change to Nexus 12cm Black & White (Including fan in my Silverstone Strider 600W PSU unit). For CPU coolink I used Zalman Fatal1ty FS-C77 12cm Cooler.
That's really nice to hear. If I decide to go air/water cooling the next time around I'm pretty sure it'll be with the S80...but if I do have the funds available to go phase then I might be going another route...but regardless, this is my fav LiLi atm. :cool:
how heavy is the case .. i heard that it is extremely heavy compared to the other lian li cases ???
Hi
I have looked through most of this thread and i couldnt see any PC-6070's or PC6070B's anyone who owns one could you post your case as well as what you think of it or can someone point me in the direction of post/s that i may have missed.
Thanks
Xteriormotive
Ok, according to their diagram it recycles its own heated exhaust back inside itself to be picked up by the intake fans?
It's a beautiful box, but it seems like an awful convoluted cooling setup.
I just purchased my Lian Li v1000b with the upper window. I'm picking it up monday from CrazyPC (219+tax) since its pretty close to my house. I'll be adding a water cooling setup to it via a D5 pump, BIX 240, TT inline temp monitor, TT reservoir with flow meter (dual 5.25), DD fillport, VL System LIS 2 VFD, etc.. I'm gonna start ordering my hardware toward the end of this month to go in it. Next week though, I'm going to be cutting out the case in the classic lianli cut spots, maybe cutout a place for the radiator on top, add my 4 UV cathodes, and plan out some wiring. Still not sure whether I'm going conroe/am2. I gatta see how much money I want to spend and what grfx card I want to go with. I'm working my full time summer intern job, so I've got plenty of cash from my first 3 paychecks to build about 4 conroe setups.. lol. I need to save some money though to pay off more college next year. I'll probably end up building a full blown system though. It always ends up turning out that way. :p
Not bad, i don't care too much for the internal wiring/tubing...and it looks like airflow through that rad would be pretty restricted...but the case itself looks awsome, and the JME applique looks really nice.
Its not an applique hehe. Its etched. and thanks :D
Fair enough...now that I look at it I suppose that does make more sense. :p
I swear...this eMac is stealing my soul...I haven't been able to think straight all day. :rolleyes:
Simple and clean, looks like almost like a boutique-built system. I like it.
yo im abiut to buy a PC-6070B and i was wondering if the Lian-Li windowed side panel for the PC-60 i the same size and would just fit right on?
Thanks
Xteriormotive
Thanks
Xteriormotive
I also want to know if the side panel fits the Lian Li PC-7B plus II
well is there any official windowed side panel for the 6070 cus i was planning on using the metal from the standard side panel for some mods
I think it will fit the 6070 because li li's site says it fits the 6xxx as well, leading me to believe the 6070 falls into that category.
WOW!!! All these cases got me going crazy here. I was thinkin of gettin a PC-7b plus II or a v1000, but now I see how nice is that s80 and now I cant even decide what to get anymore :confused: . .But defenetly a LIan-LI.. :cool: :cool:
Thats what I thought as well. But then I went to the Lian Li website, and the dimensions for the PC-7/60 and the PC-6070 are different.
PC-7: 210x450x490
PC-6070: 210x490x525
just finished buildig this one:
It is a PC-V300 all cut up inside and out. I removed the drive cage completely And mounted a radiator on top. I'm water cooling my Opteron 165 0610 (2.8Ghz, matx limiting :( ), and my x1900xt (715/775 MHz). It uses a GT series rad, alphacool topped ddc ultra, and 7/16" tubing all through. I modded a fan controller onto the front and that slot you see cut out on the right is a slimline DVD-RW mounted with a bracket I made. The sides I cut out from a blank V2000B side to replace the stock ones with dribebay cutouts. You can see worklog pics on my site http://filebox.vt.edu/users/gouldmab/v300
Brian
Brian
nice case, i checked your worklog and there are no pics of the insides. got any pics of the insides with everything? :D
uhm.... WOW?!?!?!?
good job all around. and i can see your WC philosophies are JUST like mine (and trust me they aint common!)
good job one more time!
