houkouonchi
RIP
- Sep 14, 2008
Well, I got my solaris box all up and running properly and semi stress tested and finally bit the bullet to re-allocate my array giving a bit more space now for windows and my linux OS slice:
I also was able to get everything copied over and then copied back to my machine so I am back to my machine's full glory:
Here is a pic of the SAS expander, motherboard and layout inside the solaris box and the pic of the two machines together (60TB total inside the two machines):
![](http://box.houkouonchi.jp/2tb/new/DSC_2234-small.JPG)
![](http://box.houkouonchi.jp/2tb/new/DSC_2236-small.JPG)
![](http://box.houkouonchi.jp/2tb/new/DSC_2238-small.JPG)
![](http://box.houkouonchi.jp/2tb/new/DSC_2240-small.JPG)
![](http://box.houkouonchi.jp/2tb/new/DSC_2247-small.JPG)
![](http://box.houkouonchi.jp/2tb/new/DSC_2250-small.JPG)
I am a couple weeks from moving and when I do I will have a full 45U rack to have all my stuff in. I will take a picture when all is said and done and update my storage totals. I should be at just under 90TB when all is said and done.
Code:
root@sabayonx86-64: 09:18 PM :~# cli64 vsf info
# Name Raid# Level Capacity Ch/Id/Lun State
1 WINDOWS VOLUME 1 Raid6 129.0GB 00/00/00 Normal
2 MAC VOLUME 1 Raid6 30.0GB 00/00/01 Normal
3 LINUX VOLUME 1 Raid6 129.0GB 00/00/02 Normal
4 DATA VOLUME 1 Raid6 35712.0GB 00/00/03 Normal
GuiErrMsg<0x00>: Success.
Code:
root@sabayonx86-64: 09:17 PM :~# df -H
Filesystem Size Used Avail Use% Mounted on
/dev/sdc1 129G 47G 83G 37% /
udev 13G 263k 13G 1% /dev
none 2.1M 324k 1.8M 16% /lib/rcscripts/init.d
/dev/sda1 84G 60G 25G 71% /winxp
tmpfs 13G 0 13G 0% /dev/shm
/dev/sdd1 36T 15T 22T 41% /data
osol:/data 18T 15T 3.0T 83% /osol
