Happy Hopping
- Jul 1, 2004
The Cables i made byself, running 5 Drives off each molex Plug and using Sata connectors with vampire teeth in them.
you don't think that's too risky? since it's your own data?
We have one at work that I help manage. We have Radius profiles but other then that it's a standard VPN setup. I don't know much about the ASA side as we unfortunately do not manage that part.
Our tokens will expire in a year and they're not even deployed yet. Stupid IT manager putting red tape on everything makes things hard.
I'm actually thinking of getting an RSA for my game server, but it would be a no return investment. How much do those go for anyway, I'm assuming a couple grand? I know the tokens are like 80 bucks each so it's quite expensive.
[OC]Pik4chu;1036149258 said:By ASA are you referring to one of these? If so I can probably answer some questions. As long as its not among the data center line of them that is.
Gonna be breaking 100TB in just a bit. Gonna switch my 5.25 TB 2U machine from hardware raid to open solaris and going to use its raid controller in an upgarde to the mythbox. Its going to be going from raid5 (8x500GB) to 8x2TB (12 TB useable).
Frys had a good price for retail 2TB disks for $105 which prompted the upgrade. Its also going to be getting upgraded to a norco 4020 case (from the coolermaster).
Here's my aging fileserver :
What?!?!? Dashpuppy stolez my fileserver!dashpuppy, sweet setup.
I'm itching to build a WHS. Maybe in the summer
Heh, that's actually my setup. Been using the same case for awhile now (started as a P3 w/SDRAM and a couple of Promise Ultra-100TX2 controllers).
Thanks for posting the pics Dash
*FAP FAP FAP FAP FAP*
Those plumbing fittings etc look dumb, plus you've got some pretty tight bends in those cables Oo
Who cares that they look dumb? They are brilliantly functional. And I don't see any cable bends that look outside the specs for SATA.
Oh what I would give to be able to re-wire that machine!! Here's another CM Stacker case I did earlier this year:
Man, with all those SATA cables, I bet it would look beautiful!!
Did you hot glue every sata cable in there? If you want to take it out do you just pull real hard and toss the cable?
[LYL]Homer;1036225000 said:
Just a quick question with your cpu heatsink. Do you have air coming in from the rear of the computer or fresh from the front and exhaust to the back? I ask because I think you mounted your cooler backwards but I wasn't sure if it was planned
Don't worry. If there's something always growing is your need for data storage. I started my WHS with 1TB, then quickly moved on to 4TB, and before I knew it to 6TB.HOWEVER can i still be part of the club, mines so small
WTH is that? Translation on the image contents, please!wow, that's nice jmroberts70! my plane isn't that neat.
That is not a header for the ATX power.but I'm alittle confused why you made a header for the ATX power?
AND I haven't upgraded it to 8TB yet only because I actually need a new controller (ran out of SATA ports on the motherboard), and Supermicro's controllers are rather hard to find here in Portugal.
So, don't worry. You'll get there in a flash... lol
