- Apr 10, 2003
The 25% off code came from my email as a loyalty thank you.
Lots of reputable review sites coming out saying Bethseda wouldn't give them review copies, but gamespot so far is the "biggest" one that didn't get one.
I found myself frustrated by some of The Evil Within's choices. Boss encounters, in particular, are incredibly frequent and incredibly annoying. With few exceptions, these bigger enemies require very specific, obscure steps to be defeated or a stupidly large amount of ammunition or both. Most of these bosses also launch into one-hit kill animations if they get in close, but even those that don't can usually drain Sebastian from full health to dead in two or three hits.
Every boss encounter shifted into a similar pattern for me: Start the fight, die, piece together the first thing I'm supposed to do to win, die again, piece together the second and third steps, die again and so on, until I figured out each part of the fight and was able to string them all together without a mistake.
From Polygon's review:
That sounds like a huge positive to me, not a negative!![]()
My god is so choppy and stuttery looking around with mouse. I cant play it at all even with framerate at 60. Plus it will continuously drop below 60 even though my gpu is not even close to be utilized.
Lol 60 feels the same as 30 fps for some reason.I found it ran better when it's locked at 30, which is actually 40 for some reason.
Am I really the only one having issues here or are you guys just oblivious? The game feels like garbage and just looking around has some stutter. If I turn around and around it will even grab or hitch. It has nothing to do with framerate and the controller is no better than the mouse. This is by far the worst feeling game and its not playable to me.
Come on now I play plenty of different types of games. I know exactly what type of game this or I would not even have bought it at launch. Its just not playable for me. And I did not even see vsync in the options but maybe I missed it.Are you playing with vsync on? This is a slow, methodical, crouch walking, stealth, find secrets kind of game. 40fps is enough for that kind of gameplay. Go in expecting textures comparable to Rage and Wolf and a hard survival horror game and you should be fine.
I have the game installed on an SSD if that matters.
Come on now I play plenty of different types of games. I know exactly what type of games this or I would not even have bought it at launch. Its just not playable for me. And I did not even see vsync in the options but maybe I missed it.
I did and it feels exactly the same at 30 as it does at 60.Change your setting back to locked 30fps and see if that helps.
Its not even taxing my system at all. At 30 fps its using about 35-40% of my gpu. After more testing 30 fps is smoother than 60 fps as 60 fps has a pretty bad hitch when panning around even if pegged at 60. They are both horrible though and not the least bit tolerable with the mouse. The controller is better option overall after going back and forth but that is not saying much.Did you try lower graphics settings (if there are any, don't actually have this game) and/or including lowering resolution?
Good game? Looks totally like Resident Evil 4 from the video I'm sure the graphics are better.
Smooth as butter at 30 frames per second? I find that hard to believe. And at 60 frames per second the game does look a little worse from what I've seen. And there are some others reporting the same issues that I'm having so at least it's not just me. Its crap like this though that makes me lose interest in gaming.Nope, the game is running smooth as butter for me. And I am playing at 3840x2160 downsampled to 1080P. Try re-installing your drivers maybe?
