The Evil Within
This game looks like a mind fuck. I'm loving this ! I just want to see someone fight some enemies to make my mind up.
Watching one stream and I'm like... hey that looks like a....*CRUNCH*.... trap.... yep, it was.
I dont know. I'm enjoying watching this guy suffer over and over playing it but dont know that its a game I'd really like that much. I like stealth and I like creepy, but this... I just dont know.
Will avoid watching any more streams - let alone console version - since it was a 45min stream that sold me on the game in the first place. I'm already converted. Prior to seeing the gameplay I didn't think much about this game, but atmosphere + exploration + adversity are my favorite traits for a game and they're all here.
What really hooked me on preordering: that the monsters are a bitch to take down. Its not just boom headshot and they go down like ragdolls in typical zombie shooters. And you play a guy that is relatively underpowered and having to scrounge ammo and resources to make it a few more minutes or just down the hallway. Which is why it was also good news to hear about NG+ and additional hardmodes being available after beating it once. Can't wait.
BTW, I imagine that actually playing the game yourself with headphones on or a surround system will carry more impact than just watching someone else's pixelated stream in a window. My 2c.
Yep, seems like the maps are not so big, but there is a lot of emergent gameplay. The experience is somewhat different each time because you have different ways to get defeat enemies, luring them into different areas, traps, etc. High replay value.
Must be embargo'd 'til tomorrow.
Usually reviews come out right before a game is released or at least the day of.
EDIT: Yep the embargo is tomorrow which is asinine.
EDIT 2: The The Evil Within forum on Steam disappeared about 20 minutes ago. It just loops back to the store page for now.
EDIT 3: Forums are back now and no more edits...:D
Console commands to unlock frame rate and adjust aspect ratio posted: Debug Console Commands - PC - Bethesda Softworks Forums
We promised them, and here they are! Please note that using debug console commands is unsupported by Bethesda and our customer service team.
To access the debug console, do the following:
  1. In Steam, right click on The Evil Within and select “properties” then under the General tab, hit “set launch options.”
  2. Put this in to unlock the console: +com_allowconsole 1
  3. Once the game has launched, hit the Insert key to bring down the developer console.
These are the commands you can use and some notes about each:
  • R_swapinterval <NUMBER>
    • Sets the FPS lock. Note that the numbers below are negative.
    • -2: This is the default, set to 30 FPS. This is the officially supported frame rate
    • -1: This sets the FPS limit to 60. Fully playable, although there may be quirks (we&#8217;re going to fix these).
    • 0: This fully unlocks the FPS. We do not recommend playing above 60. We will not fix any issues above 60.
  • God
    • God mode. You are effectively invincible, and certain enemy kill moves will not be used against you (Laura, for example, will not jump on you)
  • Noclip
    • Allows you to walk through walls
  • G_infiniteammo
    • Unlimited ammo (provided you have at least 1 bullet when you enable this)
  • G_stoptime 1
    • Stops time. Note there is a bug right now where using this command causes a UI element to appear on screen. We&#8217;re looking to fix that in the near future.
    • Re enable time with g_stoptime 0
  • Toggledebugcamera
    • Separates the camera from Sebastian so you can freely move around the
  • R_forceaspectratio <NUMBER>
    • Sets the aspect ratio. Default is 2.5, which is our official aspect ratio.
    • 0 is full screen, but not ideal. 1.8 or 2 is probably most comfortable for those who don&#8217;t want bars.
  • Com_showFPS
    • Turns on id&#8217;s native FPS counter
  • Startslowmotion2
    • Slows down time
  • Stopslowmotion
    • Disables slow motion
1: This sets the FPS limit to 60. Fully playable, although there may be quirks (we’re going to fix these).
Yesss. Purchased for $49.49 with fighting chance pack and season pass on GMG.
thanks for posting!...I'm surprised they included God Mode and noclip cheat codes as well...would think the developers would not want to encourage people to play that way
They didn't want you to play outside of the aspect ratio or the 30fps either. If you're going to play it outside of the way they intended might as well throw everything in.
There seems to be a messup on Steam, the game still says preload even though I can play it. However because it is preload I can't enter in launch options to use the console commands.
Showing 1.5gb vram @ 1080 on my 670 4gb.
Mouse is squirrely in the menu's sort of like Falllout in the pip boy screen. Might need fix for that later.
The official release date is still tomorrow. Embargo will be up at midnight.
They said they were gonna release the command awhile ago. :/
If you use the console command listcmds, this should provide an in-game list of all the available commands.
Here are a few of the commands from RAGE:
Code:
activateConsole       forces the console down ( or up ) and the desired fraction.. 0.5 is normal 0.2 is shifted
  addClamp              adds to a cvar, with clamping
  addWrap               adds to a cvar, with wrapping
  bind                  binds a command to a key
  clear                 clears the console
  clearHistory          Clears the console history
  con_unwatch           removes the specified console watch. Specify 'all' to remove all watches.
  con_watch             adds a new console watch - displays per frame results of console var/function printed output
  copy                  copy a file
  cvar_restart          restarts the cvar system, defaulting all cvars
  cvarAdd               adds a value to a cvar
  cvarMultiply          multiplies a cvar by a value
  cvarRandom            sets a cvar to a random value
  cvarsModified         reports cvars modified since the last call
  dir                   lists a folder
  dirtree               lists a folder with subfolders
  echo                  prints text
  exec                  executes a config file
  history               Displays the console command history
  listBinds             lists key bindings
  listCmds              lists commands
  listCvars             lists cvars
  messagemode           activate text entry in the hud
  parse                 prints tokenized string
  path                  lists search paths
  playtest_CreateAllData goes through all the playtest data and creates the necessary release data.  helper function for rob
  playtest_CreateBashTVFile goes through the passed in directory and creates a text file about the bash tv data
  playtest_CreateBombBaseFile goes through the passed in directory and creates a text file about the bomb base data
  playtest_CreateComboModel loads a playtest directory and creates all the models from everything in side that into one model
  playtest_CreateFindWellSpringFile goes through the passed in directory and creates a text file about the find wellspring data
  playtest_CreateModel  loads a playtest binary file and creates the playtest models * does a batch through all
  playtest_CreatePlayerPathCombo loads a playtest directory and creates the player paths from everything in side that into one model
  playtest_CreateTextFile loads a playtest binary file and creates the text file * does a batch through all
  reloadWater           reloads all loaded dynamic water entities
  reset                 resets a cvar to it's default value
  set                   sets a cvar (deprecated)
  seta                  sets a cvar (deprecated)
  StepParticleTime      modifies a global particle 'timeline' to debug particles in game
  TestParticle          tests a particle impact
  toggle                toggles a cvar
  ToggleMainMenu        Toggle the main menu
  unbind                unbinds any command from a key
  unbindAll             unbinds any commands from all keys
  vstr                  inserts the current value of a cvar as command text
  wait                  delays remaining buffered commands one or more frames
Um you missed my whole point of posting that which is the fact that they are saying its fully playable at 60 fps and they will fix any quirks. Before it was just use at your own risk type attitude.
How does it look? Can you take screenshots?
Well once again the VRAM requirements were vastly exaggerated. Some users are reporting maxed out at 1440p at 1.5GB VRAM usage. SMH devs.
How do I use spoiler code?
The game looks good so far, great atmosphere.
I decided not to pre-order this. I hope its good. every news site has said not to specifically because of the review embargo. I desperately want it to be good but I have to stick to my guns on this bullshit thats been going on lately.
OT but I've always wondered how GMG always seems to be able to sell new games for a decent discount...do they have some sort of agreement with publishers or are they just taking a loss on everything they sell?
Fuck "Instant Gaming". I'm not sending them a photo copy of my ID just to buy a fucking game with PayPal. That's insane.
Cause retail price is marked up 100%.. Plus they buy codes in bulk.
The "octobe-r20gmg-offerx" code doesn't work.
I'll wait a few months until there is a price drop or sale on steam.
There is a 25% off code right there on the site.
The Evil Within and Season Pass combo is 65.98 then 49.49 after using the 25% off code.
