D
Deleted whining member 223597
Guest
Multipool went down, that is where the 20mh/s went from the Doge network.
Any way to verify what the voltage is in linux?
Has anyone tried Poolwarz? For $12 a month it seems like you could easily clear that if it does its job well.
Btw scan your MOON coin wallets there seems to be a virus or something embedded with it.
does anyone use any of the dedicatedpool.com pools?
Yes. Other than the pool fees, they seem rather stable and fairly professional.
For those with 7950s, and I guess all radeon behave this way, there is a point of diminishing returns on memory clock, isn't there?
I see many people posting memory clocks at 1500mhz and I think that is complete overkill, I don't see any improvements past the high 1300s
Well undervolting helps limit cpu temp, not memory because you cannot independently control memory voltage (nor would you want to)
I don't see the point in running high memory clocks over 1400, I don't see any gains.
Unless someone can prove me wrong otherwise.
cooler core causes cooler air around the RAM which makes cooler RAM. While it may not directly cause cooler RAM it does help the RAM when you undervolt.
it varies card to card, which core and cards are sensitive to core clocks in relation to those high memory clocks. My R9 290's make there best hash rates at stock speeds because I can't find a combo of core and memory that yields better results.For those with 7950s, and I guess all radeon behave this way, there is a point of diminishing returns on memory clock, isn't there?
My 7970's like the .57 ratio, and so I am running them at 933/1650, and I have tried tons of other values and thats where my cards are the happiest, and get me the best kh/s (about 650).
you should be be getting 720+ out of a 7970 unless you are running at an intensity lower than 20
General rule is anything with a z instead of an S is trash
Yeah that sucks. I bet a bunch of people will get off of it now and it will go back down.
It jumped from over 200% profitability on Dust to about 140%. Still the best on there but not a slam dunk anymore.
It's now at 1233
multi-coin type pools are killing it because it recalculates difficulty in just a few hours compared to over a day for litecoin and a week for bitcoin
I see no problem in doing this. The technology is here so why not? I don't have long term faith in any coin other than LTC/BTC and middlecoin can't do that to LTC.While I celebrate the idea of a multicoin pool for maximizing ones profit without actually working for it... I also liken them to a Tasmanian devil of the scrypt world.
I'm not sure of the exact hash power but if you have 10,20,30+ GHash that gets pointed almost randomly at the most profitable coins it's akin to them barging in a bar, getting sloppy drunk and tearing the place up, then leaving the regulars to clean up the mess. Wash, rinse, repeat every few hours.
I can think of no spin you could put on a situation like this such that it would be beneficial in the long run to any crypto coin. If hashing power/difficulty on the BTC network swung this wildly it would be another thing on the list of unattractive qualities.
I am noticing i am getting more rejected shares but 0 HW errors. This means my 290's are mining fine, but the pools are causing the rejections. I started out on LTC and the pool I was on, I never had rejects. But on dogehouse and multi pool, I get quite a few of them.
okay make sense. So as long as my HW errors are 0, cards are operating fine.dogecoin changes blocks every minute, if your miner submits a calculation when the current block is just passing, it will get rejected
ltc changes every 2.5 minutes which should have fewer conflicts
