Sorry, but I have to wait for the official announcement in AC forum (as always). I want to keep my "job" as moderatorTop Nurse said:Well how about enlightening us wayward souls? It's supposed to be released for sale in 3 days and I already have estimated retail prices of the product in German marks. So please enlighten us silly English reading people.![]()
badash said:Anyone have some basic installation instructions for the twinplex type 1 northbridge? I think it only came with two springs and two metal clips, maybe if I stare at it more, heh.
Shoggy said:Sorry, but I have to wait for the official announcement in AC forum (as always). I want to keep my "job" as moderator![]()
Top Nurse said:What exactly are you looking for? I will try and help![]()
Top Nurse said:Well the only thing that a kit would get you over the piece purchase is a box you will throw away, an a AC case badge, and some thermal grease which you would propbably throw out with the box.. However, Sharka usually throws those case badges in with any large AC order anyway.
So lets get down to the fun, okay?
Do you want an Evo 240 or a BI Pro II radiator? Do you intend to ever get an Aquaero? And what case are you using?
16Valve said:I'll go with the Evo 240. No, most likely I wont get an Aquaero. I'm using a Lian LI PC-V1200
Top Nurse said:The DDC with the plexi top lets you run just about any size tubing you want to, but it is not currently in stocked by anyone in the USA. Sharka has them coming in on their next stock shipment though you could order directly from Alphacool if your in a hurry.
Pooky said:The plexiglass top sold at Alphacool is actually made by Watercool (www.watercool.de).
Happy Hopping said:someone should tell this co. aqua to ship w/ instruction manual.
Happy Hopping said:Thank you. It's good. But will the manual be updated in the future to include the installation of the 6800 GPU block?
Shoggy said:Aquasuite 4.31 Beta (07.01.2005)
The Aquasuite is a bit more ressource friendly now. It has network functions which are not complete ready yet.
The archive contains a new firmware 4.07a which fixes some problems with the fans on Aquaeros with hardware revision 3.07.
It also contains an update from OS 2.02 to 2.03 for people who flashed their Aquaero with 2.02. If you have to update you flash this OS update like a normal firmware, then you have to restart (on/off) your PC and the Aquaero should give you a message to flash the firmware. Back in Windows you can flash the firmware 4.07a. If you can not connect to your Aquaero you have to restart your computer again.
Shoggy said:Yes
I haven't test it so I can't tell you if it works with this version. As said it's not complete.
Top Nurse said:Have no idea. Ask ShoggyBut it ought to be pretty self explanatory as you have to take off the HSF off the card to put the AC cooler back on. The important part is to not tweak the board.
Will the northbridge version fit on a DFI NF4 SLI board.Shoggy said:Twinplex Pro
top
bottom
graphic card version
It has a height of only 11mm and solves mounting problems with a lot of SLI based boards.
The graphic card version costs 29.90 euro, the chipset version 26.90 euro. The Twinplex Pro will be available in a few days.
Nice feature: the small copper bottom is compatible to the normal Twinplex so you can change it. The bottom with seal ring and bolts costs 16.90 euro.
Yes, exactly this way.ShoNuff said:Shoggy how would you turn your current Twinplex into a "Pro?" Would that mean you simply switched the copper core? Yes???
Toonage said:Since we're on the subject of Twinplex's (albeit Pro's) I need to ask opinions of possibly a very stupid idea, but here goes: Just got one of the Asus SLI Premium's and I have a Twinplex for the NB......I removed the heatpipe connecting it from the NB to the mosfets and see that the nVidia chip is about the same size as a Barton core. The Twinplex won't mount directly to the core without modifying one of the mounting ears to clear a cap....no big deal really, but would it be a complete waste to mounting the Twinplex on top of the stock flat factory sink, thus getting the benefit of w/c and the heatpipe for the NB. The ears then clear the caps and I have long mounting hardware.
Shoggy said:ramplex
(This is a preview picture)
Will cool up to three modules. The width for the modules can be set from 0 to 8mm. Of course it is possible to use two ramplex cooler on boards with four ram slots even when they are directly side on side like on the MSI K8N (for example).
Little update: the cooler should be ready in two or three weeks. The price will be around 30 euro.
Yes but it does not cool the power mosfets nor the back of the card (1/2 the ram is located there).lemmy said:will the 6800 fit on the 7800 GFX Card? i heard it was the same?
Shoggy said:And we continue
It will be ready in a few days. It also has the dynamic core for the GPU, it cools the voltage-regulators and it has the lighting on the side.
