Icestation
- Aug 6, 2008
So not in that screen shot, every so often 1 time a day or so there will be a long enough one, I assume it's when finding the next satellite or something I will rebuffer Netflix. There are layers to this, we (the family) might be streaming 2 Netflix streams and someone will be on YouTube. So heavier usage but nothing a 150mbs connections shouldn't be able to handle. Point being is I never had this problem with my comcast 150mbps cable. That's why I said it, because it seems some people think this is the great savior to cut Comcast and I get it, I hated dealing with them. But their connection is superior at the moment. And people should have realistic expectations when entering a beta ISPLooking at your downtime stats, 17 seconds of downtime over 12 hours seems like nothing, but you still get problematic netflix pausing/rebuffering?
With that being said, it's not always 150mbs, there are "slower" satellites it seems, there are times I speed test and I have seen 45mbps.
I am using a Asus ax86u router, you can still use the starlink app to see the stats, and no it does not assign your own router a public IP.As far as not getting a public IP, I've read that all you need to do is plug the cable directly into your router
