The mesh isn't extremely restrictive imho. I had a couple of undervolted yate loons acting as exhaust and could feel quite a bit of airflow. I would try your fans first and then replace them if you see temperatures rising beyond what you desire. The top fans just snap in so they're extremely easy to replace. The fan that blows on the GPU requires a bit more to replace (removing some awkward screws) but, overall, I never thought the mesh was a problem. But... if you're used to unrestricted fan flow, you may see some difference... very subjective.
very cool, revenant...
I heard about the GPU fan being a hassle to replace.
BTW, is it the exact same fan for both the GPU/rear exhaust as in pics on the net the rear exhaust seems to have a 3 pin connector where as the gpu fan has a 4 pin molex.
Do you find the gpu fan to be powerful enough to bring cool air in through the slots on the side to blow over the video card or would a more powerful fan be recommended for even better performance. I have no clue what the rated cfm/noise is at 12v for the fan do you know by any chance? I may replace if I can find a more powerful at lower noise, perhaps yet another S-Flex or is the stock Silverstone more powerful?
wow is right. The setup looks totally buck wild. Nice and shiny and loaded with goodies. yummy indeed!
hehe.. thanks. yeah, it's full alright.. I was surprized how well I filled out the inside of that case... it's freakin heavy now also. lol.
I'm going to try and mount the Freezone in one of the top 120mm fan spots above the cpu.. I don't think that's been done before.. so it should be pretty unique.. my thought was to not cover the PWM sink on the mobo too much.. because it's going to get warm I am sure.. I wanted to keep some good ventilation near it..
Thats a great wiring job for the case. I know its a pain to hide and clean up wires due to the openess of the case. I am curious to know what is the lcd screen that you have mounted ? I went ahead and did my wiring like yours last night ( wrapping the exposed wires with black electrical tape). It came out pretty smooth. As soon as you get the Freezone mounted post some pics plz, i'm a coolit fan and some good user pics are hard to come by. I dont know if your aware but coolit systems is going to be releasing a 12 peltier cooler this year (Q2 maybe), thats what im personally waiting for.
Also, I noticed that you changed the fan that is used for the gpu cooling. How hard was it to take that cover off ?
OMFG. All of these pics do NOT give the Silverstone TJ09
Just recieved mine for my new build, and damn this case is an absolute beauty.
Anyone know the best place to snag one of these? I'm goin after the black TJ09 with the window.![]()
I bought mine at case-mod for $259 and then a small %discount for new customers, so maybe $245. Go through Froogle for $10 discount. It came just fine with no troubles. I usually go Newegg, but they were $300+ at the time, and I couldn't envision a serious RMA situation with it (not like a mobo or a gpu). I think Deadeye data had them for about the same price, I would have bought mine there, but there are in texas and so am I so I didn't want to have to pay tax. They have a great reseller rating and the guys at Jonnyguru love them. you might try "jonnyguru" in the coupon code part, works for power supplies, might work for the case.
The side windows seems to bulging out and seperating slightly from the side of the case. Nothing major but it is noticeable when looking at the case from a side view. If I push on the side of the case the window pops in and is flush with the case but then it immediately pops back out and bulges slightly away from the side panel in the center of the window. Again there is nothing installed in the case so will installing my gear and having everything tightened tighten up the side panel so the window is flush or do I have a bum side panel? I know I am nitpicking but for $300 I wanted perfect. I have heard of no mention of this happening with other users so am wondering if a user out there noticed their side panel doing this. Thanks.
