videomasterz
- Nov 9, 2006
I installed my galaxy like this also, because it keeps the wire loom more out of the way, but I debated on which way to mount it because of the gaping open top.. I don't want to drop a screw in there.. or even get metal flakes in it.. I have been covering the top of the psu when I work with the case open.. just to be safe.. I would do the same if I were you.
speaking of case logistics... for those who are wondering, the Tunic Tower 120 fits while mounted through the mobo tray slot.. just barely..
whew.
i didnt go for the silverstone tj09 case... i heard good reviews about the coolermaster stacker830.. as well... was really debating between the two... and finally decided on the stacker830 the black edition.....went with the stacker for serveral reasons.. the stacker looks much nicer imho... the air cooling is unbeatable with 4 120mm on the side panel.... and the case has an open air type design... only thing that i had to do to the case to fit my eneramx galaxy 1,000 was to bend the top metal bracket to make it fit... since that metal bracket was supposed to be for a 120mm fan.. but since the galaxy has a 140mm fan.. it doesnt really matter..
also ordered a tuniq tower 120 and im pretty sure it can fit in this case.. alot of room...
