I like what you did using the extra mounts for your speakers. I did something similar with mine.
Hydralisk, a 28" triple stand would probably work well for you. I use the hex version of this http://shop.easymountlcd.com/Deluxe...-Desktop-Clamp-up-to-28-002-0019-002-0019.htm It is a very high quality stand for an insanely cheap price.
nice man
for your standoffs did you just use extra long bolts??
No, I actually used "double standoffs" to make it work. Here's a link to the Mouser product I used. When compared to the vastly more expensive adjustable multi-monitor stands (that actually require very little adjustment), this makes much more sense.
nice thats SO MUCH CLEARER now
I might order some of those
I think LOWES has long enough and correct thread machine screws, and they sell some AL and some Nylon spacers that would allow me to put tension on the everything.
but I need to height adjust anyways, so plywood is in my future im sure
I don't think that will work. The pole that comes with the triple stand isn't going to be tall enough to use that other part. You need a hex stand like jmoberts70 has. That will have the proper size pole.Very interesting.
I'm going to try this:
http://shop.easymountlcd.com/Deluxe...up-to-28-Open-002-0020-OPEN-002-0020-OPEN.htm
with this:
http://shop.easymountlcd.com/Deluxe-Single-Head-Kit-002-0029-002-0029.htm
This is so much cheaper than other stands I've been looking at.
I actually checked out Lowes and Home Depot before I ordered from Mouser. Neither of those hardware stores had anything remotely close to what I needed. They both had M4-.7 standoffs but far too short and skinny for the 60mm total length once they're doubled up.
What do you mean by needing height adjustment? I actually am going to modify this frame further to lower it about 2"-3" but need to drill some holes and get creative with fasteners (and tear the assembly completely down again)...
I'm using 2 different branded 27" IPS and the VESA mounts are not in the same place, so one is about an inch lower than the other screen...
What is better about that stand? Doesn't the one it comes with have height, tilt, and swivel adjusts already?
For a second there, I thought your set up was in a Footlocker store.
just my simple setup wish i had money but i guess 3 x 19in monitors is good enough for nowlittle messy
You need to see a shrink about your obsession with shoes.lol my shoes have taken priority over pc stuff over the last few years
Yeah, you're screwed. A big rule with multi-display setup is try and keep each screen the same brand and model. Otherwise you get what you're dealing with now. I'm not sure what I'd do with what you have other than sell the screens and start buying same-brand displays... Sorry dude!!
It s really nice when paired with the wallpaper![]()
Looking past the shoe boxes, i really dig it man.
I am using a philips led light
