Originally posted by W1zzard
you using the vga silencer ? any way you could get a pic of the contact area?
not without some effort. I've got today off. I'll see what I can do for you.
temps, overclock?Originally posted by kapkorn
i got mine today. i have a radeon 9700 pro. i didnt remove the shim and i plugged the power right into the ati card.
it works fine. i had no troubles.
http://www.ocfaq.com/reviews/ArcticCooling/VGASilencer_Rev3/images/flatness1.jpgOriginally posted by 69cents
Rev.3 needs the shit lapped outa it. Don't try and tell me artic silver will make up those kind of gaps.
Looks good to me.
All Thermalrights have the grooves in the base... that's just how the milling machine does it's job. It's still a smooth finish. If you want to lap your Silencer, all the power to you, but I don't think it's needed.Originally posted by 69cents
If you have touched or ran your nail across the heatsink you would notice a zipping sound, Please tell me what OEM heatsink does that.the oem heatsink on my Canopus Spectra has a better surface.
I will be lapping my VGA silencer over the next two days, I'll take pics.
at least read the post before you ask a question. yes most will fit, dont know any that dont (non home made anyway).Originally posted by SycoraX
Anyone knows what heatsinks would fit on 9800pro's memory under the VGA Silencer? Are there any? Or should I use them only on the back of the card?
I need some cheap ones.
you do have a point. the thread wasnt titled to your question.Originally posted by SycoraX
Read the post? What post? You mean this 12 page thread?
Sorry, next time I'll just create a new thread and ask thereBut thanks anyways.
I just got done "lapping" mine. Didn't really do a good job just did a 350 grit then a 400 grit, and finished it off with some rubbing compound. Took the zipping out of it and now I get a stable 419.50/355 =/ I also took a little video of the "zipping" with my 707. I just have to find a host, and post it.
Good luck everyone.
Originally posted by bradbowl
I just got done reading through this huge thread and was curious if anyone had put a VGA silencer on an 9800pro 256MB card. I know they are for 9800pro's but this one is more like an XT, which is not supported. What do you guys think?
Originally posted by Mangina
I have not over applied AS5, I have not lapped the bottom of the vga silencer
http://www.google.com/search?q=lappingOriginally posted by quiksilverx181
What does this mean to lap the bottom?
Where can i get some AS5? I tried newegg nothing came up. Thanks
My Silencer's original surface. Lots of milling grooves.Originally posted by quiksilverx181
Thank you.Originally posted by jwill
hey PacknHeat... how did you go about lapping the silencer? i mean did you use a sanding block, or glass or free hand, or what? nice work by the way.
The tape is also used on aircrafts. We call it speed tape.Originally posted by SkaarjMaster
PacknHeat, is that the shiny tape that's used to wrap around air conditioning pipes that you used to close off that 7mm gap? If so, how is that working? I may try this with mine to close off the gap.
