Originally posted by MarKeR
Just installed my artic on a 9600pro from Powercolor, a supposed ultra version, comes out of the box clocked @ 400/700. I have had this card @ 510/760 using stock cooling, so I will post my stable oc results soon.
The only problem I had was that the holes in my card were ever so slightly mis-aligned with the cooler holes, eventually after about 10 mins I managed to get it to fit and sit on the gpu rather nicely.![]()
Originally posted by Shinare
I'm suprised you got it to fit at all, unless you cut off the plastic that gets in the way of inserting it into your AGP slot. As far as I know Rev1 or 2 does not fit a 9600pro stock. Thats why I sent mine back.
No mods to the artic at all, slotted in np![]()
BTW
Forgot to mention REV3 silencer![]()
ahhh, heh, thats why.I should be gettin the Giant III in the mail anyday now *knocks on wooden desk* so I'll post pics and experiance installing that behemoth on my 9600pro.
Originally posted by NeoNemesis
Shit! I knew I shouldn't have used the air ratchet to tighten the thing on!
Seriously though I didnt think it would be this hard. Is the Zalman ZM80C this difficult to install? If it is then I'll get my buddy to do the install, he is much more patient then I am.
I don't see what the problem with breaking your card is unless the Warranty is expired. If the thing breaks after you try to install the silence then just put the old fan back on, ship it back to whoever sold it too you and tell them that you are pissed off because their fucking video card doesnt work and that if they don't replace it then you will take your buisness elsewhere. I guarantee they won't check if the thing works or not.
The way I see it is that its there fault for not making the thing durable enough.
Originally posted by KickAssCop
.. and that is the reason I opt for the Giant II/III.. it has a little thin aluminum plate popping out of the base so that whatever the case it makes good contact w/ the core!
Vga Silencer did not impress me one bit due to the whole cheap aluminum block thingie and plastic cover..
Sorry to hear about the loss of your cards though!![]()
ok seriously, who wants to get their card deformed by a cooling kit? wtf?
I still say there are way better solutions than this one.
*subliminal messaging* Giant III is what you want.![]()
Originally posted by W1zzard
i talked to arctic and they say they have had single reports of problems with fans but the too high power draw is something they never found any hard evidence for .. please drop me a pm if you experience this problem so maybe this can be worked on ..
on the 9500/9700 shim lower than core thing they say the backside mounting clip will deform the card a little bit pushing the core towards the cooler and this will make good contact .. can anybody verify this is true?
you can buy an adapter. That'd be the easiest. Or you could just splice it in with another 4pin molex.Originally posted by SkaarjMaster
So SKiTLz or anyone else, is there any way to plug the 2-pin fan connector into a 4-pin power supply plug?
Originally posted by Digital Viper-X-
if you mean to say that the 9500/9700 shim was lower then the core then I'd hace to say that's incorrect, my shim was clearly higher then the core and i barley got any thermal paste on the hs from the core when i pushed it down.
my core was lower than the shim. I just used a decent amount of AS3 (not gulps). Probably no more than I would usually. Everything works flawlessly for me.Originally posted by W1zzard
on a large number of 9500/9700's the core is lower .. my question was if someone can verify that the vga silencer makes good contact on these cards
