contrast ratio means the depth of black !
That is not what contest ratio means. Contrast ratio is the difference between the brightest white and the darkest black.
Black levels are a completely different measurement.
senna89 has a point. Contrast ratio is usually determined by comparing against a fixed "usable" bright point (usually 120 cd/m^2)--in which case the contrast ratio and black level are inversely proportional.
ahahahahha
The contrast ratio will be compared whit same brightness of white
the white brightness is same, the principal factor is the brighness of black.
Kinda hard to explain differently but, basically "has a point" means that your conclusions and thoughts are correct - either all, or some of them.... Maybe someone can come up with a better alternative explanation than me.senna89 said:what the meaning "has a point" ?
So why couldn't the 27" be 16:10? I guess it would've been even more expensive, and maybe Samsung wanted to keep it under $1000?
Searching the web for the panel they reference (LTM240CL01) seems to show 8-bit+FRC (effectively 10-bit), instead of 6-bit+FRC. That would probably align better with its placement as a "professional" class monitor. I really hope so, considering the Dell U2412M is now pretty much guaranteed to be 6-bit.Good news, for some, the 24 PLS will be 1920X1200. Confirmed by TFT Central. 6-bit panel hmm.
http://www.tftcentral.co.uk/news_archive/24.htm#samsung_s24a850dw
I've been pushing of(f) buying the 2711
Do not do that. If you have even the slightest desire for a clear picture, you'll regret it, and good luck getting your money back from Dell. It took me 4 months and numerous phone calls with their foreign outsourced lackeys to get them to cough up my $700+ (their $115 restocking fee subtracted, of course) when I returned the U2711 I bought last year. Never, ever again.
Keep waiting.
the S27A850D is out and available many places. does anyone have one yet or know of any reviews. is it good for gaming, does it have 120hz
it is not backordered! its available and in stock at 44 online stores.
anyone have any info on this monitor?
Could the uniformity issue cause the low contrast ratio, meaning if they address that then the contrast will go up?
I wish samsung still made more true S-PVA panels as in my opinion i find those to look best for my use. I like the great contrast and the Color shift is minimal and definitely better than the new c-pva ones. Theres also zero off angle glow. I had an H-IPS panel and got rid of it because I found the contrast to be crap, and the off angle glowing annoyed me like crazy.
It's only useless to him. It's best just to ignore Senna89.
