sabrewolf732
- Dec 6, 2004
I'd like the try and see if I can get a more stable clock speed. I'm on air.
Well Archaea, running 2 instances of hanbrake on 72 threads and mining ether on 2 x RX 480s and 2 x RX Vega 64: 1074 Watts at the wall. Did see it over 1100 Watts for a second or so.
So I guess really a 1200w PUS would be all I needed.
Random question for owners of the liquid cooled version, anyone having issues with black screen crashes and system freezing? The owners thread on the ocuk forums has had a few people reporting problems with their liquid cooled version, been around 8 or so returns in the owners thread there from what i'm seeing. Not a massive amount but they've only sold around 60 ish liquid versions as they're hard to come by, (still waiting on my pre-order). Doesn't seem to affect the blower fan version, just the liquid version for some reason.![]()
Yes that will be needed first and the most, but hopefully they're already working at crossfire next to it. I really wonder how far away it is..I would say, they are probably trying to get all the new features enabled properly before they worry about crossfire.
Me too. PLP eyefinity the P monitors get rotated in the bezel correction screen making it VERY difficult to adjust.well found my first bug.
You can't use Eyefinity and bezel correction. Bezel correction locks up my main display to a black screen every time I try to use it. Bezel correction worked fine with the Fury X crossfire pair - so it's gotta be a bug.
Specifics: (3) 32" HP Omen 1440P displays connected via display port, running 75hz each with 10 bit color. 7680x1440 eyefinity --- but with bezel correction should be more like 7800x1400 -- as soon as it pulls up the yellow triangle adjustment screen (standard bezel correction screen) the main middle screen fritzes out - with a pixelated mess of yellow and gray dots. I can run three screens, I can run Eyefinity at on games at 7680x1400 - just not bezel correction.
no negatives at all. No flicker at any fps range using ultimate. Gotta say it has been perfect thus far.
Once yesterday with GW2 (guildwars 2) a DX9 game, had to reboot. And for now After OCing my CPU it doesn't post a screen for the bios. Goes to windows and works just fine just not bios so maybe when I reset and try Pstate OCing it may fix that issue.Thanks! Well I took the plunge and spent more money on the Samsung CF791. Although I'm finding it very finicky with Display port and ultimate engine turned on. I get black screens at post, and some games just go black screen. Have you experienced this at all JustReason?
For now I'm using HDMI as it seems to be working fine, but I hate when something doesn't work right from the get go.
I think I saw that mentioned by others, although I am not sure how feasible or rather good an idea that is.Anyone's blower fan shut off at times? When my PC is idle for a while, the fan shuts off.
What do your clocks drop to, out of curiosity. My Wc drops to 852mhz core 167mhz memory.When the fan shut off, the card was cool to the touch though.
my rx480 cards did this - no concern - it was by design. My Vega doesn't have a fan to test.Anyone's blower fan shut off at times? When my PC is idle for a while, the fan shuts off.
So far what cable are you using? I wonder if the cable is the issue with some. I gather most use the cable with the monitor, which seems hefty enough, but too short for me so I have never tried it.
Sorry neither. But so far no flickering issues and I am using the ultimate engine. Skyrim and Fallout work perfectly, capped at 75hz. Doom capped @99hz looks amazingly smooth (capped to stay in the Freesync range).Yeah I'm using the cable that came with the monitor. I also tried the cable from my LG ultrawide. Same thing with me that I can't see the bios loading screen either. It could very well be the cable as I used a cable that came with my dell 27" that was the first to have displayport in my eyefinity days and it didn't even show the windows desktop.
Do you happen to have Hellblade or battlegrounds by chance? Probably hasn't been discussed much due to either the monitor is owned by nvidia owners, or they simply have turned off ultimate engine because of the flicker.
I have this issue now where embedded videos (on Twitter, Facebook, etc.) cause the whole computer to become choppy and unresponsive for 10 - 15 seconds at a time. The mouse won't move and nothing will work for the time period. If I have the task manager open, CPU usage is fine (i.e. under 10%). I thought maybe it was a video codec issue, so I installed K-Lite and tried enabling different hardware rendering modes, which helped a little bit, but it's still choppy. I don't recall this ever being an issue until maybe the latest AMD driver. Anyone else have this problem?
All of the standalone 56s at MSRP sold out within a minute of listing if not earlier. The first standalone 56 on newegg might have been out before it even showed up on search, although its difficult to know for sure. I grabbed one of the game packs off BB since I don't have either game, but it's listed as "reserving" item which makes me think the retailer oversold. That said, it also says "get it by Wed, Aug 30"Well, has anyone been able to snatch up a Vega 56 yet? They are at MSRP but none show as being available.
Guys, do your vega have coil whine?
Mine screams almost as loud as the fan under load.
The combination is almost intolerable. It's sitting on a cardboard box naked on my desk though. So I'd imagine having it in a case would help.
What game do you have it in. I haven't noticed it on my watercooled Vega yet.Guys, do your vega have coil whine?
I think I have it in most of the games I play, especially demanding games. Dishonored 2, fallout 4, even some older but graphics intensive titles.What game do you have it in. I haven't noticed it on my watercooled Vega yet.
I get it the very moment I fire up furmarkNo, I haven't noticed any coil whine. I just ran FurMark for a few minutes, no whine at all and the fan noise wasn't even that loud at 100%.
