Not really relevant. The point is we’re entering an upgrade cycle soon which will drive gaming revenue.
Sure it will drive increased gaming revenue, it just won't come close to their main business revenues. Especially if/when they finish buying ARM.
Yes indeed, read, that is all that is needed, just pop in RT and Tensor cores, throw them in the mix and no space will needed to hook them up, added buffers, caches, logic on other parts of the chip to make them work -> wow your so brilliant.You should have googled a little bit harder:
https://www.reddit.com/r/nvidia/comments/baaqb0/rtx_adds_195mm2_per_tpc_tensors_125_rt_07/
Let't put it this way. They have one core technology that they can sell into multiple markets. Kudos to them. Too bad AMD doesn't have the moxie/smarts/resources to do the same.Not really relevant. The point is we’re entering an upgrade cycle soon which will drive gaming revenue.
I wouldn't even call it a technology; technologically-speaking, GPU hardware isn't that complicated.Let't put it this way. They have one core technology that they can sell into multiple markets. Kudos to them. Too bad AMD doesn't have the moxie/smarts/resources to do the same.
Don't forget that Nvidia acquired Mellanox.Let't put it this way. They have one core technology that they can sell into multiple markets. Kudos to them. Too bad AMD doesn't have the moxie/smarts/resources to do the same.
triple slot? for fuck sake
That thing screams space heater. I think I'll end up waiting on the EVGA hybrid. Did wonders for my Titan XP.
On the plus side, it could spawn a new wave of modders and modding as people dremel out the side and front of their cases to make it fit.This does not bode well for power consumption on the cheaper Ampere parts.
If the heat goes into the space around it, mission accomplished.That thing screams space heater. I think I'll end up waiting on the EVGA hybrid. Did wonders for my Titan XP.
If you think Nvidia is a gaming company first and foremost, you really aren't paying attention to what they do. Gaming gpu's are simply a nice easy byproduct that they get to sell for nice margin these days.
It does indeed, absurdly large.Looks like a photoshop fake to me.
LOL! Pick one.Lol, big and ugly. Hopefully it's at least fast and quiet.
From what I have heard, I would suggest that is the real deal FE cooler.The previous "3080" Cooler leak was a smaller 2 slot card and there were a few different and consistent images, that weren't obviously photoshopped.
This has obvious photoshopping going on, and strikes me as a little questionable size for NV cooler.
https://twitter.com/GarnetSunset/status/1296916731378704391
3060 $400
3070 $600
3080 $800
3090 $1400
uhg screw those prices, horrible, 400 dollars for a 60 series is insane
If this is real then I don't think it would even fit in my case. Especially with the 12-pin connector being connected to the back of the card. I don't think I could maneuver the cable through the holes in my case and keep it from running into the front case fans. Hopefully the 3080 is a more reasonable size.
How can you say that without knowing the performance, transistor count, ect? But mainly performance of course. What if it pushes Cyberpunk as well as a 2080?
3060 $400
3070 $600
3080 $800
3090 $1400
It wont more then likely and 400 is beyond what most people looking in that class want to spend.
Of all those, the 3080 looks the best as it easily outpaces the 2080ti. $400 for the 3060 will be tough to swallow if it is a 6 GB card.
Dude said the 3090 is a Titan replacement, so maybe 24 GB. The 3080ti could come a little later, at closer to $1k and then maybe then rest of the 'ti' cards during a refresh next year. For example, a 3060ti that is slightly cut down 3070 for $400.
Just hope they never use 'Super' again.
IMO pricing determines class, not the name. People will be looking for cards in their price range. Not cards with a certain number on them.
Agreed. Never understood why people say "if it is a xx60 it should be this price" or "if it is an i5 it should be this price".
What if that xx60 or i5 is performing better than last year's xx80 or i7??
I am sure the Nvidia will have stuff in the sub $300 range with good mid range performance as well.
Someone else pointed out that the 3090 appears larger than it actually is, since it's 3 slots and raised up closer to the camera.
Here is the pic with the pci-e connectors normalized for size:
How is this difficult to understand, the branding has always indicated its place in the market. Maybe it's just what I'm used to, but it's going to be odd eventually have 60 + skus all be various forms of high end cards. 60 and 70 series cards have been traditionally mid range for generations now. Most line ups used to have 2 or 3 high end products (GTX 780, 780 ti and Titan for example). It was that way up through the 1070, but since the 2000 series things have changed. Even with AMD challenging, if they can subsist on higher prices, they will.
