- Jul 29, 2011
Could you guys live with these temps? This is PO -22+200 MHz. This is Furmark and Cinebench running together for worst case scenario. Cooler is Noctua DH15G2.
Bottom line, with 5090FE, CPU temps can get close to 90 and even exceed. GPU hits 600 watts, but GPU temps or throttling is a non-issue. The new FE cooler is brilliant at cooling the GPU. It is the CPU that is the problem. Most of time, CPU at 87ish.
At idle, CPU is like in the low to mid 30s. Wondering if I should repaste.
What you need is a case with airflow capable of moving 600W+ of heat out. You've got a portable space heater inside there.
