Sobek said:The pics work, iupload may have been down while you tried to look at them.
Starhawk and anyone else, the virus or worm problem is whenever I restart my PC, after it boots and the WinXp Pro user logon screen comes up and I sign in, the PC either restarts or I get this message:
Windows could not start because the following file is missing or currupt: <windows root>\system32\hal.dll
Please reinstall a copy of the above file.
I have to do a repair install of windows which takes about an hour. I've done it 3 times now. I've rebooted in safe mode as well and run Nortan which found some things but didn't fix the problem.
Some of the virus's/worms that it found that kept popping up every few minutes while auto-protct was running are:
logppmj.dll
s_elite.exe
Backdoor Agent B
I downloaded and ran a file on Symantec's site that is supposed to get rid of Backdoor Agent B but when I rebooted to run it again I still had the same problem. I can make do with just not restarting for the next few days but I would like to get this fixed. I plan on ordering 2 Seagate 200gig+ SATA's to RAID when I get done with BT and a fresh Windows install will be on them.
tom61 said:Get SpyBot Search and Destory ( http://spybot.safer-networking.de/en/index.html ) and run it in safe mode. It's really good at fixing 'file missing or corrupt' problems from removing viruses and getting rid of trojans. It's free for personal use, too.
G.I. Jesus said:did you tape and paint the DVD drive and thats it? you didnt open it up? and just paint the top? because painting it will void it too so why wouldnt you remove the stickers? but looks good man.
flat4 said:nice idea with the dvd burner. i mite have to use it. everything is looking real good. keep up the good work.
Sobek said:I just stealthed the drives.
CGFMaster said:wow! that is an idea that never had crossed my mind. Very cool stealth mod!!!![]()
Sobek said:Really?! I know I'm not the first to cut off the tabs and mount them to the drive trays using mounting tape. There's a piece of mounting tape on the inside of the faceplate that pushes the button when you press the front of the faceplate. I had to mash it in really well so that the drive doesn't keep ejecting itself when it tries to close.
The tape on the side panel is where the window with the Stargate will go eventually. I left it on there from when i was doing the mockup months ago.
CrimandEvil said:Just so you know the pics aren't working for me.
CrimandEvil said:How about here? http://www.nicoritschel.com/freehosting/index.php
CrimandEvil said:Odd since I just loaded the page up twice now.Then again I am using Firefox which we all know to be superior to IE.
Legion© said:I think the question everyone will have is 'when are we going to see some more?'
Do we have to wait 17 weeks while you train? or are you still going to be able to work on this?
I've been following it for a while, and have been pining for an update for a while...
