Elios said:hehe look cool now all you need to make is a "Z.P.M"![]()
Dragon4000 said:Hallo Sobek and all users
I am a big fan of stargate and I want also modiict my PC.
1. Sobek I want ask you if you cann scan your Stargate draw in high quallity. Then I and other cann download the image and can make their own mods.
2. At all have some other one stargate draws??
Dragon4000
Sobek said:Are you asking for the image of the gate that I drew on poster paper? I can't scan anything because I don't have a scanner. I can take more pics if you would like.
Dryer sheets work just as well and leave that oh so nice lemony scent.Ozone77 said:Sobek, if you want to avoid having to clean up the dust in your system, i would buy some cheap AC filter (it looks like a very thin sponge), then cut it in squares/circles and put them in front of your suck-in fans. (sanwiched between 2 fan grills, for example)
CrimandEvil said:Dryer sheets work just as well and leave that oh so nice lemony scent.Seriously try them, I got the tip from a chick I know and it does work.
Dragon4000 said:Hi
Yes I mean the image of the gate. I would like it when you take more pics of it.
my english is not so good.
Dragon4000
My PS2 has pretty much crapped out on me. So no GTA for Crim.Sobek said:I almost baught some small AC filters when I was at HD. I'll try the dryer sheets instead. Thanks CrimandEvil. I'm still playing GTA for now though.![]()
Sobek said:I'll take some more pics of it later. Keep in mind that it is just a planning guide. I could tell that your are not a native English speaker but I still understand you. Where are you from?
HELLODragon4000 said:I am from Germany! I am learning english at school but it is not my favourite subject.
Dragon4000
Yeah, I got another borked PS2 to help fix it (since that DRE trick didn't work for very long) and scavenged to laser from that but the borked PS2 was a different revision then mine (same series though) so now I'm pretty much screwed.MONST3R said:HELLO
hey crim is your ps2 doing the disc read error. if so pm me and ill give you instructions to fix it.![]()
Ozone77 said:I havent read much lately, so you might have an answer already... If you were planning on having a moving gate, an easy and cheap way to do it would be with a clock mechanism so it would turn constantly (no fancy stopping).
CrimandEvil said:Very cool. How are you going to attach the PVC? You've worked with JB Weld right? Since I'm here I was wondering something, do you think I can use JB Weld to glue together both Arylic and some "L" brakets?
I hate when the batteries die like that, I think my Dremel is starting to give up the ghost.![]()
StratocasterMaster said:Hmm, I would think a clock would be too slow, althought stopping it would be easy with a simple circuit to cut power from it. Now I can see making a rotating gate pretty easy... however having the chevrons move in/out would be next to impossible without some major work given the scale you are working on.
~Kris
