My new TJ08-E Clean and simple
snip
Very clean - great build to digest where everything is and comes from. Its fun to sit and wonder how its all routed, but nice cable sleeving and dressing as well. Two thumbs up on the w/c/ PSU, that is just plain sick @ 1,700w - holy %$#@%$#@%$!@ - Frank wants one now....................My new TJ08-E Clean and simple
Yep, i have a cooling system under my floor on top of the case it's only a shroud to create some more space above the PSU![]()
Very clean - great build to digest where everything is and comes from. Its fun to sit and wonder how its all routed, but nice cable sleeving and dressing as well. Two thumbs up on the w/c/ PSU, that is just plain sick @ 1,700w - holy %$#@%$#@%$!@ - Frank wants one now....................![]()
gotcha. it really looked like an exos, but then it didnt look high enough. you should post your rig in the water cooling sticky too. i bet they would be very interested in it as well. you should also put some pics of the under-floor cooling system too if you can get some. sounds pretty legit. so if everything is water cooled including the psu, whats the extra space above the psu in the shroud for? routing your tubing? also, if i didnt mention it before, AWESOME rig, truly impressive and incredibly clean. 10/10 on cabling for sure.
slowly being refined...i call it the cm "snow" sniper case...suggestions welcome!
snip
Looks great, but holy overheat batman! Those GTX580's look cramped!
CSC...i'm a bit partial to white, i think you've done a great job here sofar! 10/10 for cabling.
thanks PB4UGO, your build is what inspired me to go the route i did. without your help i would just have a plain black case with parts thrown in.
Thanks! the 580's are suffucating, begging for fresh air. they whine at 50db in hopes that one day they can escape the 85C heat.
to ekuest, thanks for your recommendations. the design of the case makes it difficult to slip the cable through the cage without drilling but i think i can figure out a way.
regarding the dimms, i was thinking about adding more, but i'm conflicted as to continue with a red build or go more on the blue side. i also dont want to paint the dimm heatsink and void the warranty. i would hate to have to paint the mobo heatsink though.
My suggestion: no pink. And get a better looking case. There is not much to do about your cable management.
....I do have one question.. WHERE IS YOUR POWER SUPPLY??????????.....
Lol. I was thinking the same. Is that a double wide case?
Lian Li PC-A05NB:
As anyone who owns this case knows, there is very little room and not much for cable management in this case. But I did my first cable mod job and it turned out alright.
Instynx whats the model number of that pci cooler you're using on the a05n?
You did a great job!![]()
