Post your Intel Burn Test Temps
Dmac122383
I have a quick question about using IBT and the speed(gflops) it shows during the tests. I just put together a rig for a buddy it has an i7 2600k OC'd to 4.5ghz 16gb of ddr3 ram @ 2133mhz and an asus maximus iv p67 board and I only get around 50-60 Gflops. Why is that number so low compared to most of you guys with similiar clock speeds, I've seen anywhere from 90-120 gflops from you screen shots.
SonDa5
Update to W7 SP1 has performance tweaks for Sandy Bridge processing.
PolRoger90
I just upgraded from my i7 920 to a 3930k on a Asus Rampage IV Formula. I have it clocked at 4.7GHz atm with 1.37vcore and LLC on "High". I was suprised that this chip doesn't run hotter, but then again, this setup was able to tame my power hungry 920 quite well.
Running a 180.3 rad!...that will keep things cool. :)
Durty
when i test a few times on my 2700k the wattage would go over 1k i dont know if thats a bug or not but scared me might be the software i was using, i was using core temp when i did the intel burn
SonDa5
Spawn447 nice speed and temperature and performance.
JDanser
Also if you haven't already, disable Hyperthreading.
PolRoger90
Biostar TZ68K+/2500K on an open air bench...Bios vcore set at 1.26v LLC enabled. Air cooled Noctua NHU-12P with push/pull and ambient temp ~21.2C.
jdk
Finally got around to running IBT on maximum and taking a screenshot. I saw a maximum power draw of 212 watts in coretemp.
Dantrax
EDIT: Notice that it's on maximum load and not standard that many people in this thread seem to be running. On standard I get like 52c compared to the temperatures in the image above.
I have an i7 3930k on an Asus R4F but Real Temp only shows the temps on 4 cores. What version or settings are you using to get the other 2 cores temps in Real Temp 3.70. So used to 4 cores I thought it was normal, until I saw your temps. POST EDIT: You're using the GT version which does show all 6 cores when I "DUH" use that as well. Anyway with an Archon & 2-140mm Silverstone penetrators push/pull blowing upwards on the IBT maximum test I had 78/73/73/72C maximum temps. But I'm just running everything at stock right now, so I think Archons coming out & NH-D14 is going in. If that doesn't get me some stable #s, then I might try the Corsair H series coolers. Just not loving the H2O idea in my PC.******Post Edit****** Removed Archon & put NH-D14 in with oem fans in a pull/pull setup blowing upwards. Set 16GB ram to 2133MHz,1.64vdc,11,12,11,36,1N & re-ran IBT standard in 142.51 secs. (7.4s-7.5s/118-119) Had Real Temp GT 3.70 show Max temps of 69,63,62,62,65,63C at 100% load & 100x38.0 or 3800.07MHz idles at 32,29,29,30,33,26C. Thats a 9C plus for the NH-D14 vs. the Archon, I didn't think NH-D14 would best the Archon by that much. That's a nice surprise :)
kgoldman1
My computer passes 50 test and still it crashes, how in the world does a pc pass this test hitting temps of 73 C and then crash on idle lol
manny1222
Still haven't figured out how to paste pictures.
I got 73C max temp with a 2500K OC to 4.5GHz and 1.30vcore with a HR-02 Macho
Edit:
I turned off the iGPU and got 64C with Vcore set to 1.25. Dunno if it has anything to do with it, but I'm happy with it.
Dantrax
IBT 132.29 sec. 6.90-7.01 sec. at 127.80-129.51 Gflops. Real temp gt max 73-67-66-66-69-67C, load 100%100.0 x 42.0 = 4200MHz. Kingston 16Gb ram at 2133MHz, 11/12/11/36/1T at 1.64vdc. Using an NH-D14 with oem fans in pull/pull blowing upwards at 1200 rpms. I also ran 2 hrs. of Prime95 at the same settings with a max of 79C. Not to shabby for an NH-D14. :D
Russ
edit: I had some idiotic settings and was throttling myself to get "5.0 ghz." With a proper setup (and using LinX w/ AVX instead of IBT), the settings I posted here didn't come close to stable. Removing my temps/pics since they aren't really valid.
rvborgh
i was just doing stability testing of my quad opteron setup... ran for about 5 hours or so in Intelburn "maximum" mode...
Setup is Quad Opteron (4 x Opteron 6100 ES chips = 48 K10 cores at stockish 2.1 GHz)... 4 x Noctua U9 D0 A3 Heat sinks.
i'll be running these at 3 GHz soon... they do run just fine at that speed... just need to update the fans, and add additional heat sinks/fans to the VRMs/MOSFETs before i try running IBT for extended periods of time. Currently, at 2.1 GHz... i see around 650-700w on the Kill-a-watt.
IBT is truly an amazing stress test though.
