Post your hard drive Power On hours!
stephen2002
Currently running:
Samsung 840 PRO with 44,521 hours.
Samsung 850 EVO with 29,493 hours.
My computer rarely gets turned off, so that's just about the age of the drives.
rgMekanic
[H]ard|News
nnnnnnnecro!
No point in making an identical thread. Decided to check my oldest drive for shits and giggles.
cjcox
On the HP Z840:
2639 hrs: HP Z-Drive 512GB (NVMe via PCIe)
2698 hrs: Micron M600 512GB (SATA)
2699 hrs: Micron M600 512GB (SATA)
19640 hrs: Seagate Barracuda 2TB (SATA)
27990 hrs: Seagate Barracuda 2TB (SATA)
1164 hrs: Toshiba Canvio 4TB (USB 3)
1502 hrs: Toshiba Canvio 4TB (USB 3)
1139 hrs: Toshiba Canvio 4TB (USB 3)
1263 hrs: Toshiba Canvio 4TB (USB 3)
cjcox
On the Dell Optiplex 990 SFF:
73158 hrs: WD Blue 640GB (SATA)
34537 hrs: WD My Passport 3TB (USB)
23794 hrs: WD My Passport 3TB (USB)
35033 hrs: Hitachi Touro 1TB (USB)
Have 2 x WD My Passport 4TB (USB) that are also connected, but the version of smartmontools I have doesn't have the drive in it's database. The are newer than the 3TB drives, so will have less hours.
pioruns
My two oldest drives are 1TB Hitachi. Bought them already used with many hours on the clock. Spinrited them few times over and over and all bad sectors have been identified and spared out. For last two years or so there hasn't been a new bad sector.
I use these drives in RAID1 configuration. Normally a consumer would throw them out, but thanks to Spinrite, RAID1 and frequent monitoring I guess there's still plenty of life in these two :)
Device Model: Hitachi HDS721010CLA332
Temperature_Celsius 30
Power_On_Hours 22472
Reallocated_Sector_Ct 1655
Device Model: Hitachi HDE721010SLA330
Temperature_Celsius 32
Power_On_Hours 72219
Reallocated_Sector_Ct 563
72k hours that's 8.25 years online.
drescherjm
It appears the largest here at home for the drives currently connected to my linux pvr is over 74 thousand:
Code:
jmd0 ~/shell-scripts # sh examine_smart.sh
Wed 08 Apr 2020 12:35:03 PM EDT
sda User Capacity: 5,000,981,078,016 bytes [5.00 TB]    Serial Number:      44E3K004FK7A
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   027   027   000    Old_age   Always       -       29233
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   253   000    Old_age   Always       -       0
sdb User Capacity: 4,000,787,030,016 bytes [4.00 TB]    Serial Number:      W300FC1Z
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   032   032   000    Old_age   Always       -       59697
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       4 4 4
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
sdc User Capacity: 10,000,831,348,736 bytes [10.0 TB]   Serial Number:      JEH733UN
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       1031
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
sdd User Capacity: 10,000,831,348,736 bytes [10.0 TB]   Serial Number:      JEKU14JZ
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       1194
sde User Capacity: 4,000,787,030,016 bytes [4.00 TB]    Serial Number:      PL2311LAG2UNAJ
  9 Power_On_Hours          0x0012   093   093   000    Old_age   Always       -       50101
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       8
sdf User Capacity: 5,000,981,078,016 bytes [5.00 TB]    Serial Number:      44E3K005FK7A
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       39900
199 UDMA_CRC_Error_Count    0x0032   200   253   000    Old_age   Always       -       101
sdg User Capacity: 4,000,787,030,016 bytes [4.00 TB]    Serial Number:      PK1331PAJ29R7S
  9 Power_On_Hours          0x0012   098   098   000    Old_age   Always       -       20434
sdh User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      S2HGJDWZ806051
  5 Reallocated_Sector_Ct   0x0033   252   252   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       74790
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   252   252   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   252   252   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0036   200   200   000    Old_age   Always       -       0
sdi User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      S2HGJ1BZ836643
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       62930
Got a simailar number at work on this server (smallest capacity file server):
Code:
fileserver1 shell-scripts # sh examine_smart.sh
Wed Apr  8 12:37:55 EDT 2020
sda User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      MN1220F31GZG7D
  9 Power_On_Hours          0x0012   090   090   000    Old_age   Always       -       74597
sdb User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      82N2K3VNF
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       4
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       62541
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
sdc User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      82N2K3UPF
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       98
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       60974
sdd User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      42D1KCFNF
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       65303
sde User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      MN1220F31NWX7D
  9 Power_On_Hours          0x0012   090   090   000    Old_age   Always       -       74596
sdf User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      Z1X059LQ
  9 Power_On_Hours          0x0032   033   033   000    Old_age   Always       -       58696
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       1
195 Hardware_ECC_Recovered  0x001a   052   020   000    Old_age   Always       -       124392974
sdg User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      Z1X05ABQ
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
195 Hardware_ECC_Recovered  0x001a   053   009   000    Old_age   Always       -       146892868
sdh User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      MN1220F33JULPD
  9 Power_On_Hours          0x0012   091   091   000    Old_age   Always       -       66397
sdi User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      82N2K3URF
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       613
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       62554
sdj User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      42D1KCO0F
  9 Power_On_Hours          0x0032   001   001   000    Old_age   Always       -       65304
sdk User Capacity: 2,000,398,934,016 bytes [2.00 TB]    Serial Number:      42E2KC0NF
M76
This is my oldest drive:
Hitachi HDT721010SLA360
Power on time: 1956 days 22 hours
Start/Stop count: 5189
Used as my trash drive, primarily for downloading stuff onto like drivers and software updates, etc.
But another has the most power on time:
WDC WD30EZRX-00AZ6B0
Power on time: 2030 days 19 hours
Start/Stop count: 744
Yes it is a notoriously unreliable WD Green, I've had these in raid, and none failed. They are retired and only used as offline backup now, so the Hitachi will overtake it within a few months.
Nemesis_001
I have 3 of them and they all still work and are in use. I bought the F4 drives since they were highly regarded as great drives at the time. I never had any issues with them.
This is all 3 of them,
I had 4 of them (2TB) until about a year ago. Replaced them with 8TB WDs, they had close to 75K hours on them, no issues at all. Even managed to sell them.
wagoo
Probably this guy..
Code:
Model Family:     Hitachi Travelstar 5K500.B
Device Model:     Hitachi HTS545016B9A300
User Capacity:    160,041,885,696 bytes [160 GB]
Rotation Rate:    5400 rpm
  9 Power_On_Hours          0x0012   001   001   000    Old_age   Always       -       80146
240 Head_Flying_Hours       0x0032   001   001   000    Old_age   Always       -       80103
limitedaccess
I can't quite remember but I might have bought this drive with a A64 3000+ build, so physically the drive might be 16/17 years?
I have an older 20GB Drive that was being used until maybe around a 1 (2?) years ago when the machine it was in was still running Linux. If I have time I might connect it and see what it reads.
Nenu
[H]ardened
Haha, thats nuts.
Easily the longest uptime posted so far.
And great operating temp for an old drive, mine always got hotter over time as the silicon aged and perhaps the bearing oil degraded.
LimitedAccess didnt apply to that drive :)
sirmonkey1985
[H]ard|DCer of the Month - July 2010
Drive Model: WDC WD1600AAJS-22PSA0 (was used as my boot drive in an athlon x2 6400+ and phenom II x4 940 up until 3 months ago when i built my ryzen system and finally bought an SSD)
[09] Power-On Hours/Cycle Count: 1/Always OK, Worst: 1 (81584 hours / 9.31 years)
Drive Model: Seagate ST3500630AS (not bad for a 40 dollar hard drive from fry's back in 2007 but it's my last surviving one of 6.. 2 of the 6 died after 1 year and the remaining 3 died about 3 years ago)
[09] Power-On Hours/Cycle Count: 26/Always OK, Worst: 26 (65497 hours / 7.48 years)
both drives are still connected to this system, i want to see if i can hit 10 years of power on hours with both of them before they die or if i retire them.
updating..
WD160 power on hours: 101,726 hours / 11.6 years
seagate ST3500 power on hours 83,118 / 9.49 years
one thing i find odd though is my 850 evo has 1000 more power on hours than my boot drive SSD but it's a year older than the 850 evo..
SamirD
Love seeing the 100k+ poh. :) Especially since the drives were pretty run of the mill at the time. (y)
Zarathustra[H]
Wow.
100k is a bit more than mine, but mine are no spring chickens.
The 16 drives in my remote backup server are as follows:
Code:
  9 Power_On_Hours          0x0032   086   086   000    Old_age   Always       -       10421
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       5389
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       5786
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       15244
  9 Power_On_Hours          0x0032   039   039   000    Old_age   Always       -       45172
  9 Power_On_Hours          0x0032   037   037   000    Old_age   Always       -       46160
  9 Power_On_Hours          0x0032   038   038   000    Old_age   Always       -       45727
  9 Power_On_Hours          0x0032   038   038   000    Old_age   Always       -       45457
  9 Power_On_Hours          0x0032   067   067   000    Old_age   Always       -       24610
  9 Power_On_Hours          0x0032   046   046   000    Old_age   Always       -       39866
  9 Power_On_Hours          0x0032   042   042   000    Old_age   Always       -       42838
  9 Power_On_Hours          0x0032   040   040   000    Old_age   Always       -       44125
  9 Power_On_Hours          0x0032   039   039   000    Old_age   Always       -       44536
  9 Power_On_Hours          0x0032   041   041   000    Old_age   Always       -       43464
These are all 4TB WD Red's.
There were originally 12, but I expanded the pool about 7 months ago. Makes me wonder if the 4 newer drives are those WD SMR drives based on recent news stories...
The other shorter hour ones were warranty replacements.
My 10TB Seagate Enterprise drives in my local server in my basement are a lot younger
Code:
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       21381 (178 63 0)
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       20372 (230 196 0)
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       20372 (247 161 0)
  9 Power_On_Hours          0x0032   075   075   000    Old_age   Always       -       21974 (234 25 0)
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       21764 (38 22 0)
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       21381 (241 254 0)
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       21639 (108 245 0)
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       21639 (169 121 0)
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       20686 (54 155 0)
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       20685 (22 191 0)
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       20968 (78 250 0)
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       20968 (183 212 0)
And funnily enough, despite their bad reputation historically, my Seagate drives have been much more reliable than the WD RED drives were at this age. Have not lost any of them yet!
ochadd
74,216 hours and counting. 4 drives all with the same hour count in a ZFS RAIDZ1. It's what I call my "nice to have" data, backup of the backup.
