^Planning on using my Xbox360 that I am getting next month on my Sony G400, I think I may have the black bars to, what resolution are you running the Xbox360 there?
i do have a projector in the room if i want a bigger picture currently my ps3 is hooked up to it and the white 360 is just 1 of the launch consoles with a pgr3 faceplate^ Are those two separate 360 Elites I see? Very nice! The 360 on the right is white on top though... what's up with that?
Have you considered a bigger TV?
[IM]http://farm3.static.flickr.com/2305/2378543970_fbdd4c73a1_b.jpg[/IMG]
Added new HK AVR247 receiver and htpc.
Need to center the entertainment center (yes the floor is a tad lower in the middle, the flat i live in is part of a building that was built in 1805 so it's cool with me.)
I think i'm going to add some fake plants or something to liven it up or something..
and yes i'm going to fix the cable![]()
Nick,
What settings on the TV do you use to play games? Also, how far do you sit in front of the TV when playing games/watching BD movies?
small remark:
what about a cable cover like this:
Cable cover (eBay)
it is colored like the wall and hardly visible by far.![]()
Or he could fish them through the wall...
Not the power cable...![]()
Woot for budget Home Theatre/Gaming Center![]()
Why not I have mine going up through the wall.
huh? why wouldn't he be able to snake the power cable through the wall?
It is finished.
Cliffs: Just skip all the text and look at the pics.
The current iteration of my home theater actually started when I wanted to get new speakers for my PC. I ended up getting an X-LS 5.1 system from AV123 but my spare receiver was an old Technics that didn't support any modern surround sound formats and didn't have 5.1 analog inputs either. So I stole my Marantz receiver from my home theater. This started an upgrade that took about 14 months from first item replaced (receiver) to last item added (amplifier) and actually replaced every single component in my HT (which wasn't too bad to start with).
So I needed a new receiver, ended up with a Denon AVR-2807 (and a Denon 1930ci DVD player to match it), and that's what started the whole upgrade process. I replaced my 30" Samsung HD CRT with a Samsung HLS-6187 61" DLP. Next up was a 360 and a Wii. After that came a Toshiba HD-A3 and a Monoprice 5x1 HDMI switch to deal with my ever increasing number of HDMI sources (I'm currently at five). A PS3 purchase rounded out my crop of current gen consoles.
After that I decided my speakers weren't quite cutting the mustard (B&W S3s and a Infinity Intermezzo 1.2s subwoofer). I'd always been impressed with the subwoofer so I found a pair of the matching bookshelves to listen to (the Infinity 2.6) and I was hooked. I got a pair of the 2.6p (p is the passive version of the bookshelf, I didn't want to hassle with power cords since I'd be using them as surrounds) and a pair of the 4.1ts. After a couple months of watching eBay and Audiogon I finally found a 3.5c, the matching center.
For those that aren't familiar, these were Infinity's second in command at the time, with an MSRP of $7,000. The Prelude MTS was their top dog, costing a couple grand more for a pair. Each speaker has a 6.5", a 3.5" and a 1", with an internally amplified (850 watt BASH) 12" subwoofer. All the drivers use Infinity's Ceramic Metal Matrix Diaphragm material, which is basically ceramic coated aluminum. Very light and very stiff.
The center has 2 5.25" drivers, a 3.5", and a 1", and an internal 250 watt amp for the 5.25"s.
The surrounds are a 1" and a 6.5". These are available with a 250 watt internal amp but mine are the passive version.
The next buy was an HTPC to go with everything. I'm a sucker for big black aluminum boxes, so I went with Silverstone's CW-02B. Currently residing in it is 1.2 TB of storage (more to come), an Asus M3A78-EMH HDMI motherboard, AMD 5000+, and 2 gig of G.Skill, running Windows Vista Premium. I've got a 7950GT laying around that I may throw into it.
My final purchase was the Emotiva XPA-5 1000 watt amplifier.
So, without further ado, the pics:
Top rack, from the bottom up, Emotiva XPA-5, Pace TDC-778X and external drive, various mineral samples, and sitting on top are my Dinovo Edge and Wii/PS3 chargers.
Bottom rack. HTPC, Denon AVR-2807, Denon 1930Ci, Toshiba HD-A3.
It feels very good to finally be "done." I'm sure I'll eventually get upgradeitis again but at least right now for pretty much the first time ever I'm completely happy with the system and don't feel the need to add or replace anything.
Just my 2 cents, but why don't you move your sub and look at putting your center under your TV and I would also move your rack and place both infinity's next to the tv for a cleaner look with all that money you spent I would definately try to get it looking abit cleaner and uniform.
^^^probably sounds better the way he has it...most people who buy that kind of audio gear don't just put it in some random ass place; they take there time to find just the right spot.
So I don't duplicate my posts, my set up is in the HTPC thread: http://www.hardforum.com/showpost.php?p=1032389084&postcount=383
